Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: need some advise
  1. #1
    Nothing but a Thing Texas Nick's Avatar
    Join Date
    Jan 2014
    Location
    Texas, Pasadena
    Posts
    1,186
    need some advise
    hey guys.
    ive noticed since i bought/ installed my Dominion SS relocation bracket about a month and a half or so ago. that my ride quality from the front of the suspension got just a tad bit rougher.
    and as of 3-4 weeks ago, its been feeling worse, i feel all of the bumps on the road, and when i off-road as well. the best way to describe it is whenever the tires are overly inflated and a harsh ride is given is almost exactly how it feels .
    but my steering wheel, dash, hell almost the whole front end seems to shake and feels pretty bad.
    so this leads me to believe two things.
    that maybe my wheels need to be rebalanced, because even when im on a nice flat road my steering wheel still tends to shake, and a little more so at higher speeds.
    also i think that maybe i didnt torque something right?
    which leads me to ask you guys, how exactly are you supposed to properly torque the suspension? am i supposed to have the suspension in the air while the jeep is being supported by the frame?
    or am i supposed to put jack stands under the axle supporting it? or is it supposed to be torqued while it sits on the ground?
    also if it helps, i am still stock other than the SS and the relo bracket.
  2. #2
    LOSER
    Join Date
    Sep 2013
    Location
    Ontario Canada
    Posts
    206
    there is a thread on here about suspension.
    loosen everything in the front end with jeep on the ground give it a shake then torque everything to propper setting!
    is the jeep lifted? the steering stabalizer shouldnt give you a harsh ride or wheel shake thats caused by other components!
  3. #3
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,438
    Quote Originally Posted by Texas Nick View Post
    hey guys.
    So the SS is not the stock unit? did you properly adjust the SS from turn to turn?
  4. #4
    Not That Kind of Engineer olram30's Avatar
    Join Date
    Oct 2013
    Location
    wyoming
    Posts
    7,226
    did you tighten the track bar while the jeep was lifted?
  5. #5
    Guy with a Red 2-Door cozdude's Avatar
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    18,685
    as mentioned make sure everything is torqued back to spec. your trackbar should be at 120 ft/lbs.
    October 16, 2013, wednesday early evening, east of the pacific ocean, selectee for truly random and boring Parking lot photo of the moment grand platinum prize winner!
    2011 JK
    EVO Bolt-on Coilovers, EVO 1/4 pounder w/ stinger, 37" Cooper STT Pros, PR44, and some EVO stuff
    Awaiting install-
    On Order-
    Want list- Evo carrier and skins, PSC hydro assis
    jlwrangler.com
  6. #6
    Join Date
    Jan 2014
    Location
    Texas, Pasadena
    Posts
    1,186
    Quote Originally Posted by just-lift-it View Post
    yes i have seen this plenty of times but it only discusses the torque settings on the bolts, not how to actually do it.
    so i should loosen up the track bar, tie rod, and the drag link on the ground and tighten it up on the ground?
    Quote Originally Posted by jeeeep View Post
    correct, i broke the stock SS about a month and a half after i got the wrangler and got the Bilstein one because i thought i NEEDED a SS, so i bought it as soon as i could at a 4wheelparts store as soon as i could cause i didnt want to wait for one to take a long time to get shipped to me, but later found out one isnt really necessary.
    and yes it doesnt collapse on either end.
    Quote Originally Posted by olram30 View Post
    i actually did it on the ground, because i didnt know how i should do it
  7. #7
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    18,685
    so i should loosen up the track bar on the ground and tighten it up on the ground?
    yes you should only need to do the track bar.
    2011 JK
    Awaiting install-
    On Order-
    jlwrangler.com
  8. #8
    Join Date
    Jan 2014
    Location
    Texas, Pasadena
    Posts
    1,186
    ok. can i do it with it jacked up with the axle supported with jack stands or can i have just the front on ramps?
    since i am stock, it is a little tight under there when i try to use the torque wrench.
  9. #9
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,386
    Do your best to torque everything with the jeep sitting under its own weight on flat ground. This ensures the rubber bushings aren't prelaoded as would happen if you torqued everything with it jacked up and the set it back on the ground.
  10. #10
    Join Date
    Oct 2013
    Location
    wyoming
    Posts
    7,226
    Quote Originally Posted by jesse0920 View Post
    Do your best to torque everything with the jeep sitting under its own weight on flat ground. This ensures the rubber bushings are prelaoded as would happen if you torqued everything with it jacked up and the set it back on the ground.
    good example of what you are saying as told by mel wade
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
