Tonytony9's 2008 Jeep Wrangler Unlimited Build Thread [Part 1]
tonytony9
January 2014:
*Radio Installed
May 2014:
*Rugged Ridge 1.5inch Wheel Spacers Installed, Plasti Dipped Rims (Matte Black), Wayalife Windshield Decal Added (White), Soft Top Installed, MOPAR Hitch Installed, Jeep Logo Blacked Out
December 2014:
*Hankook Dynapro ATM 295/70/17 Tires, New Steering stabilizer, tie rod end/drag link, Serviced front differential (@114k)
January 2015:
*AntennaX (13-inch) installed, Firestick (red) installed with Rugged Ridge Mount & Spring, New Light Lens & New PIAA Lights & Blacked Out Light Trims
February 2015:
*Transmission serviced
March 2015:
*Rock Hard License Plate Relocation Bracket w/ ORO LED light/brake light, Shortened Firestick, Touched Up Plasti Dip
May 2015:
*JL Audio 500/1d Mono Amp, JL Audio 10W6v2-D4 Sub Woofer 10", JL Audio SGR-10W6v2/v3 Gasket/Grill, Sound Ordinance Ported Enclosure.
*Polk Audio db6501 6-1/2" Component System, Polk Audio db 651s 6-1/2" Slim 2-way Speakers, Pioneer GM-D8604 600W Class FD 4-Channel GM Digital Series Amplifier
June 2015: ~123,400
*New Back Brakes
August 2015:
*Removed "X" Stickers
November 2015: 124,000
*Rough Country 2.5inch Lift w/Stock Coils & Shocks
*Named the Rig "Sigmund"
Before:
During:
After:
December 2015: 124,000
*Brake lines replaced throughout entire truck
January 2016: ~124,500
*Limo tints added throughout truck (including hardtop windows)
June 2016: ~126,850
*Fixed cruise control lever & whining pulley
*Installed a Gibson Performance Dual Extreme Cat-Back Exhaust Black Ceramic & replaced entire exhaust pipe w/ a Walker OE Replacement Exhaust Pipe
*Fixed broken OE horn - replaced with Hella Twin Super Horns
June: 2016 ~127,050
*New Radiator installed (pipe snapped, truck towed to my shop, fixed)
July: 2016 ~128,131
*Road Force Wheel Balance performed
August: 2016 ~128,385
*Four wheel alignment
*New outer & inner tie rod, right
*New Tie Rod & Adjuster Sleeve
*New Front Brake Pads & Rotors
March: 2017 ~133,529
*New Right Rear Rotor, Caliper, and Pad
July: 2017 ~134,000
*New Water Pump
*New Thermostat & Thermostat Housing
*New T-Stat Gasket
*Flushed & Replaced Engine Coolant
*New LED Back-Up Lights
*New LED Fog Lights
January: 2018 ~141,288
*New DB8 Halo Projector Headlights
*New LED Blinkers
*Oil + filter, engine coolant topped
December: 2018
*New Harmonic Balancer
*New Trans Coolant Lines
May: 2019 ~157,000
*EVO 1/4 Pounder Stubby Front Bumper
*Fox 2.0 Shocks (10k miles) Rears
*Fixed Ground Wires
*Full Tune Up (New Spark Plugs/Coil)
*Trailer Wire Harness Installed
July: 2019 ~158,000
*Rigid Industry Dual Front Window Cubes Installed
*New Black OM Floor Mats
*New Skinny Fenders Installed
August: 2019 ~158,000
*New Badlands 12,000lbs Winch Installed
*Removed Spare & Tire Carrier, Back Bumper Removed.
November: 2019 ~159,340
*New radiator installed w/ new tunes
*Universal Joints replaced
December: 2019 ~160,000
*Upgraded Head Unit to an Alpine W650
Actually Ive heard they are the Ferrari of winches lmao
No.
Can’t tell if you’re being facetious or not.
I have a badlands 12k as well as many friends, the 9k sucks, they work great for what we do with them and as long as you don’t use that stupid fuse block thing they come with they work fine. If you’re looking at cheaper winches I would recommend them over others. If you’re looking for high end and faster cable speed, keep looking.
