Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Vibration - Drive shaft?
  1. #1
    Nothing but a Thing ERAUGrad04's Avatar
    Join Date
    May 2014
    Location
    SF Bay Area
    Posts
    1,486
    Hi all!
    Looking for a little input on a slight vibration that I have been chasing since installing my lift and tires. The vibration comes on around 50mph and gets stronger the faster I go. To be fair, the vibration is slight, but noticeable.
    The Jeep is a 2014 Unlimited Rubicon with about 1,500mi on it. The lift setup is a 3.5AEV with the 5160 Bilsteins along with the Fox ATS steering stabilizer, Dynatrac ball joints and a Synergy track bar. The tires are 35" BFG KM2s mounted on 17" AEV Pintler wheels. I did all the mods within about 100th of being new.
    I've had the tires balanced probably 5 times now including a road force balance on a Hunter 9700 balancing machine. Everything points to the tires being balanced.
    I'm starting to wonder if I have a driveline vibration. The front drive shift is stock and has not been off road yet. I know the front DS is prone to the boot failing on the taller lifts and is currently on my radar for replacement.
    All said, are the factory shafts prone to vibration at lift heights similar to mine? I am thinking about pulling the front DS this afternoon and see how it rides, but was curious if anyone has any thoughts or similar experiences.
    Maybe I am just expecting a smoother ride from a 3.5" lift and 35" mud terrains. If that's the case, just tell me and I'll get over it and go have a beer!
    Thanks all!
    ERAU
    Mauser's Build Thread
  2. #2
    Old Timer 2013rubirick's Avatar
    Join Date
    Jul 2013
    Location
    Pine Grove Ca
    Posts
    3,326
    Is the vibration coming from the steering wheel or the jeep its self
    Sent from my SAMSUNG-SGH-I537 using WAYALIFE mobile app
  3. #3
    Been Around the Block Buster3479's Avatar
    Join Date
    Mar 2014
    Location
    Lexington Park, MD
    Posts
    462
    Pull the front driveshaft and take it for a ride. It won't cost you anything but a little time. I installed a 3.5 RS over a year ago and had tire balance issues. It always happened between 50 and 57 mph. It sounds like you've covered that (took a road force for me to do so). I later had vibes from a front 1310 driveshaft I didn't seat properly, but that was a very different feeling. Check your track bar bolts for tightness while you're under there (more death wobble than vibration).
    2012 Deep Cherry Red Freedom JKU "Beast", 5.13 Auto, 4:1 Xfer Case, ARB front/rear lockers, Dynatrac Prorock 60 Fr / Pro 60 Re, 40x13.5R17 Nitto Trail Grapplers, Raceline 8x6.5 Beadlocks, 4" Evo Plush Ride Springs, Billstein 5160 shocks, Switchpros, EVO Fascia & AEV Tire Carrier, EVO 1/4 lber / Stinger, Warn 9.5 CTI, EVO Air No Limits on Demand & Links, EVO Sliders, EVO Protek Skid System, EVO Rockstars, Heated Truck-lites, JW Speaker Fogs
  4. #4
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,800
    If you're still running a factory front shaft, I doubt that's where it's coming from. But, just to be sure, does the vibration oscillate or is it constant at that speed?
  5. #5
    Join Date
    May 2014
    Location
    SF Bay Area
    Posts
    1,486
    Quote Originally Posted by 2013rubirick View Post
    I would say its more the Jeep than the steering wheel. It's not a major vibration, just noticeable enough...
  6. #6
    Join Date
    May 2014
    Location
    SF Bay Area
    Posts
    1,486
    Quote Originally Posted by Buster3479 View Post
    I just re-torqued all of the suspension bolts about 500 miles ago and paint lined all nuts/bolts while I was at it.
    I am kinda thinking it is still a tire issue, but just trying to rule out all other options.
    Thanks for the suggestion on the DS. I should get a chance to pull the DS later this week.
  7. #7
    Join Date
    May 2014
    Location
    SF Bay Area
    Posts
    1,486
    With the factory shaft, I really don't expect it to be the source of the vibration like you say.
    I would say that it is relatively constant, but minimal. I am starting to think that I am just chasing the slight vibration that is to be expected with 35" MTs....
    As a side note Eddie, I think I remember seeing you are down in the SoCal area and it looks like we are just going to miss you guys. We are headed down to the LA area tomorrow with a stop off in Pismo Beach.
    Next time you guys find yourself in the Bay Area, let me know!
    Morgan
  8. #8
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,800
    Okay, if it were really your front drive shaft, the vibration would oscillate like a sine wave. If it's relatively constant, it's most likely something else - maybe you're feeling the lug thumps of your MT's.
    Also, we're back up north now and will have to get some kind of run going soon.
  9. #9
    Been Around the Block Sithwindu's Avatar
    Join Date
    Jan 2013
    Location
    Corpus Christi
    Posts
    482
    Yeah I think it's your mt's brotha. I have mud grapplers and feel a slight vibration but it's from the aggressiveness of the tire.
  10. #10
    Join Date
    Jul 2014
    Location
    N/A
    Posts
    447
    Did you road force those puppies ?
    Up Until my last balance .. I always had a small vibe at 60-70. Last shop was finally able to fix it. I will be going back there again.
    I'm guessing tires too.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
