is your steering wheel straight?
any recommendations on a drag link replacement? suspension is all stock until next year when i plan to get coilovers. maybe something a little beefier than stock that doesnt require a lift or anything crazy until I fully upgrade everything...?
RLTW!!!
I have a brand new factory one. Only 500 miles.
im a long way from oregon...
RLTW!!!
Brown Santa goes door to door if you want me to ship
thanks for the feed back. i figured it was probably an alignment issue because the drag link being bent. ill replace it and have it aligned and see if that takes care of the issue.
I forgot to mention, I also get the ABS kicking in under harder braking even though its not anywhere near hard enough to cause skidding. I guess i'll do some googling on wheel speed sensors to find out if one of those may have gone bad as well. just seems like a big coincidence for a sensor to go out right after I bend my drag link.
Anyway, again thanks for the feed back everyone!
RLTW!!!
The ABS engaging means 99.9% you have a bad speed sensor. Being as new as it is I wouldn't think the wheel bearing went bad. You can get just new sensors so your not spending the $150 for a bearing unit. A good start would be pulling each sensor out of the bearing assembly and giving them a look over. Also you could check in the sensor hole to see if the toner ring has any irregularities in it. Cheap place to start.
It should be the only wire going out to the wheel (usually run with the brake line) and its only held in with one screw. Its probably under the brake rotor so brakes would have to come off but its pretty simple once you get into it.
