2008 Jeep Wrangler 2 Door (Built Rig)
mcmahonbj
No Longer For Sale. Part-out thread will be posted once I get the pricing set for all the things.
mcmahonbj
2008 Jeep Wrangler (Purchased August 2012)
42,257
-Bosch MircoEdge Wipers 40715 @ 42848 8/11/12
-Added Prestone Extended Life Coolant @42843 8/11/12
-Banks Ram Air Intake @43106 8/16/12
-Rampage Billet Black Fuel Door Cover @43106 8/16/12
-Rugged Ridge Floor Mats Front @43106 8/16/12
-Rugged Ridge Door/Glovebox Handle Cover Kit @43106 8/16/12
-303 Aerospace Protectant Wipes Applied (Top, Bumpers, Fenders) @ 9/1/12
-AntennaX 13” Rubber Antenna @43964 9/4/12
-Nitto Terra Grappler 285/70R17 Tires @43970 9/6/12
-Rough Country 2.2 Steering Stabilizer w/ Relocation Bracket @44590 9/13/12
-Wade In-Channel Smoked Vent Visors 2 pc @47111 11/8/12
-Oil Change Mobil 1 5w30 Full Synthetic @47128 11/9/12
-Mobil1 Oil Filter M1-102
-Drain Pan Bolt w/ Gasket
-Drilled Holes In Door Handles and Mirrors @47128 11/9/12
-Rock Krawler 2.5” Stock Mod System @50700 4/12/13
-RK Front Sway Bar Extended/Disconnect Links
-RK Front and Rear progressive coils
-RK Double Adjustable Front Track Bar
-RK Rear Track Bar Relocation Bracket (Needs Weld Still)
-RK 2” Front and Rear Bump Stops
-Bilstein 5100 Shocks Front and Rear @50700 4/12/13
-Front: 24-186872 (x2)
-Rear: 33-186887 (x2)
-Crown 0-6” Stainless Steel Brake Lines Front and Rear @50700 4/12/13
-Crown 1.5” 5x5 Wheel Spacers Front and Rear (Red Loctite) @50700 4/12/13
-DynoMax Evolution Competition Exhaust #39516 (Cut 2.5”) @50700 4/12/13
-Mopar Tinted Soft Top Window Kit (30%) @50700 4/12/13
-PlastiDip Stock Wheels Black (x5) @50740 4/16/13
-Oil Change Mobil 1 5w-30 Full Synthetic @50785 4/20/13
-Mobil 1 Oil Filter M1-109
-Windows Tinted 35% @54500 6/20/13
-Bosch MicroEdge Windshield Wipers 40715 @ 54890 6/29/13
-Custom Cargo Trunk Floor Mat @ 54890 6/29/13
-Duralast Idler Pulley @55139 7/21/13
-Duralast Serpentine Belt @55139 7/21/13
-Oil Change Mobil 1 5w-30 Full Synthetic @55139 7/21/13
-Bosch 3422 Oil Filter
-New Drain Bolt w/ Washer
-Autolite Platinum Spark Plugs (gapped .050) @55139 7/21/13
-Removed Exhaust Heat Shield @55139 7/21/13
-Rotated Tires @55139 7/21/13
-Oil Change Mobil 1 5w-20 Full Synthetic @58135 9/30/13
-M14-1.50 Drain Bolt w/ Washer
-Fram CA10348 Air Filter @58135 9/30/13
-Alpine CDE-143BT @58135 9/30/13
-Optima Yellow Top Battery @58200 11/23/13
-Dana 30 JK Front Carrier Case (3.73 Up) @58273 3/11/14
-Lube Locker Dana 30 Differential Cover Gasket @58273 3/11/14
-Lube Locker Dana 44 Differential Cover Gasket @58273 3/11/14
-Nitro Gear 4.88 Package (front/rear) @58273 3/11/14
-EVO MFG Rock Star Skids/Relocation Brackets @58273 3/11/14
-TeraFlex Dana 30 Differential Cover @58273 3/11/14
-TeraFlex Dana 44 Differential Cover @58273 3/11/14
-TeraFlex Front Axle Sleeves @58273 3/11/14
-TeraFlex Front Axle Gusset Kit @58273 3/11/14
-80/90 Front/Rear Diff Fluid @58273 3/11/14
-OE Tranny Fluid @58273 3/11/14
-TeraFlex Rear Sway Bar Extended Link @58273 3/11/14
-Oil Change Mobil 1 5w-20 Full Synthetic @58273 3/11/14
-Mobile 1 M1-102 Oil Filter
-Goodyear Wrangler MT/R Kevlar 37x12.50R17LT 124Q @58350 4/18/14
-ATX Slab Beadlock Wheels 17x9 (x5) @58350 4/18/14
-(Removed) Crown Automotive 1.5” Wheel Spacers @58350 4/18/14
-(Removed) Rubicon Wheels and Nitto Terra Grappler Tires @58350 4/18/14
-ACE Engineering Pro Series Rear Bumper w/ Tire Carrier @58365 4/19/14
-Lifetime LED SR (x2) 7.6” Light Bars @58365 4/19/14
-Vector Offroad Tailgate Plugs @58365 4/19/14
-Superchips FlashCal @58365 4/19/14
-ACE Engineering Pro Series Front Bumper w/ Bull Bar @58365 4/20/14
-Lifetime LED SR 21.5” Light Bar @58365 4/20/14
-ACE Engineering Wide Tubular Fenders @58365 4/20/14
-ACE Engineering Bolt-On Rock Sliders @58365 4/20/14
-ACE Engineering Rotopax Can Mount @58365 4/20/14
-Mopar Rubicon Take-Off Sliders @58365 4/20/14
-Rugged Ridge Hood Lock @58365 4/20/14
-Offroad Elements Superior Grill Mesh @58365 4/20/14
-Sprayed Underbody w/ Bedliner @58365 4/20/14
-Truck-Lite LED Military Self-Defrosting Headlights @58365 4/20/14
-Trek Armor Seat Covers @58375 4/21/14
-ACE Engineering Cargo Basket @58375 4/21/14
-Spiderwebshade JK-1 2D @58375 4/21/14
-ARB Air Compressor @58375 4/21/14
-Angry Offroad Power Distrobution Box @58375 4/21/14
-Quadratec Extreme Duty Battery Terminals @58375 4/21/14
-6 Switch Panel @58380 4/22/14
-OTRATTW Switches Installed @58380 4/22/14
-Rock Lights
-Windshield Light Bar
-Front Bumper Light Bar
-Rear Bumper Lights Bars
-Air Compressor
-Kicker 40CS654 6.5” Coaxial Speakers Front/Rear @58400 4/24/14
-PSC Fire Extinguisher Holder @58400 4/24/14
-Rear Axle Breather Hose Extended @58400 4/24/14
-Smittybilt D-Rings On Bumpers Front/Rear @58400 4/24/14
-Vector Offroad UFOs Hood @58400 4/24/14
-Rock Hard License Plate Relocation Kit w/ LED Light @58400 4/24/14
-MOPAR License Plate Delete Plug @58400 4/24/14
-RECON 10500 Waterproof Winch @58545 4/25/14
-Synthetic Line
-Wireless Remote
-10’ Tree Saver Strap
-Snatch Block
-x2 D-Rings
-Waterproof Cover
-ACE Engineering Winch Plate Mount @58545 4/25/14
-PSC Aluminum Hawse Fairlead @58545 4/25/14
-Factor 55 Pro Link (Red) @58545 4/25/14
-Factor 55 Winch Lock @58545 4/25/14
-Rugged Ridge Tow Harness @58545 4/26/14
-Hopkins Mag-Flat Magnetic Harness Bracket @58545 4/26/14
-Smittybilt Tailgate Cover @58545 4/26/14
-Rugged Ridge Aluminum Hood Latches @58545 4/26/14
-Bilstein Steering Stab. @58545 4/27/14
-Syngery Steering Stab. Clamp @58545 4/27/14
-Cobra 18wx II CB Radio @58545 4/27/14
-Fire Extinguishers Installed (x2 front/rear) @58545 5/2/2014
-Daystar D-Ring Isolators (x2 pairs) @58545 5/2/2014
-ARB Medium Recovery Bag @58545 5/2/2014
-Oil Change Valvoline Full Synthetic 5W20 @63255 6/26/2014
-Goodyear 21348MP Oil Filter
-Tires Rotated (all five) @63255 6/26/2014
-OEM Black Jeep Front Emblem @63300 7/1/2014
-Rockridge LED Conversion Taillights @63300 7/1/2014
-Plastidipped Front Grill Black @64000 8/7/2014
-Lucas Heavy Duty Gear Oil Change 85W140 @65176 8/23/14
-Front D30/Rear D44 Diffs
-Lucas Heavy Duty Gear Oil Change (rear diff only for inspection) @64550 10/9/14
- Bosch MicroEdge Windshield Wipers 40715 @64550 10/9/14
shadow21
Is this not a fair asking price
Personally I think you way off the mark. Your asking full blown retail plus 5-8k over. Your jeeps retail value is between 13-16k depending on wear and tear it shows. Let say you actually have 15k in mods expect to get 25% of that back. It's not fair but that's just life. I'd say a "fair price" would be 18-19k. It sucks but I think that's reality and the curse of the 2-Door Jk's is they are just don't hold the resale like the 4-door
mcmahonbj
Your actually wrong Kbb and NADA it is 17-18k for retail. And yes I have $15,739 in parts so no I'm not asking retail value or even close I am asking 5k over NADA so explain how that's detail value plus 5-8k over. So as you were but thank you for your input. Price is or best offer also if you noticed. Thanks have a nice day.
shadow21
Yea so with 0 interest in your Jeep and you asking if the price is fair you get butt hurt when you get the answer? Well let me break it down for you. Your Jeep is a 2-Door 6speed sport. Your right it does say 17k HIGH END RETAIL. Your jeep needs work throw out bearing (if I'm not mistaken but I could be) this is a internal throw out bearing and could cost a lot more than 50 to replace if so. After spending the better part of 4 months looking for a 2-Door for my dad I ended buying him a 2011 Sahara with Leather, Navi, 3.5" lift and Moto Metal wheels and 35's with a 6-SPEED for 20,317. It's a great looking jeep and only had 13k miles when I picked it up. The reason for the price on this jeep being so low was the manual transmission and 2-door being that BASICALLY NOBODY WANTS them so they don't bring a bunch of $$$$. Also met me state that Built Rigs don't have a Dana 30 up front nor do they have a stock 44 in the back. So that 15k you spent you might as well of flushed it down a toilet. Now "as you were" well weren't as you had 0 interest in your over priced under built "built rig".
mcmahonbj
If you have no interest than go elsewhere. I never claimed it to be heavily modified I disclosed everything so no need to be a tool.
I also said $50 part which is true I am not factoring labor because someone can replace themselves.
