do you mean abs sensors and connector? or oil lines ?
the sensor and connectors - they're the black plastic lines going behind the brakes usually tied to the brake line and have rubber grommets on them
you'll need to remove your wheels to see them behind the brake lines.
this mentions it and shows what the line looks like, it doesn't discuss changing it out but if you do a search on Jeep JK ABS Speed sensor you'll find several articles on replacing it.
after looking up codes, may also be an issue with the PCM, you'll have to take it to the dealer for that.
