Page 19 of 19 FirstFirst ... 9171819
Results 181 to 188 of 188
Thread: 2014 SEMA Switch Pros - AWARD WINNING PRODUCT
  1. #181
    Hooked steve_r2's Avatar
    Join Date
    Jun 2013
    Location
    Dubai
    Posts
    173
    Before I pull the trigger on this can anyone tell me how this will work with a dual battery system ?
    I am not electrical minded so simple explanation needed lol.
    I have a dual battery system (Painless Performance Digital Battery manager P/N 40120) in 2009 JKU.
    Are these compatible ? Do I substitute one for the other or are both ok ?
    Appreciate your thoughts
    Cheers
    Nulla tenaci invia est via
  2. #182
    Advertiser Switch-Pros's Avatar
    Join Date
    Dec 2014
    Location
    California
    Posts
    42
    Quote Originally Posted by steve_r2 View Post
    Cheers
    You would connect the Switch-Pros battery cable directly to the MAIN battery.
    The Painless Performance directions say: Do not connect anything other than the digital power manager to your auxiliary battery....
    Using both systems is no problem. I would still use the switch panels low voltage disconnect feature to make sure none of your switch panel loads drain your battery.
    Robert
  3. #183
    Join Date
    Jun 2013
    Location
    Dubai
    Posts
    173
    Quote Originally Posted by Robert@Switch-Pros View Post
    Robert
    Thanks Robert,
    It's great when the manufacturers actually take time to respond to a thread .
    Greatly appreciated.
    Steve
  4. #184
    Fresh Catch Magilla's Avatar
    Join Date
    May 2013
    Location
    Monterey, Ca
    Posts
    15
    Switch Pros SP8100 and Genesis Dual Battery Setup
    In mid-June, I installed the switch-pros system in my 13 JKU with a Genesis dual battery setup I had previously installed. Installation was smooth as silk, other than not being able to mount the unit on the firewall because of the dual battery setup. I ended up making my own bracket and mounting it to the Genesis mount on top of the battery. I had a couple questions and called their support line at 5:15 and left a message. Laura called me back by 5:30 while she was making dinner, took my questions, and then called me back 1o minutes later after conferring with her husband. I was reading some voltage on the wires with the switch off, turns out it's normal because of the mosfet circuitry. My other question was regarding hot/hey hot, but I just had to move a fuse over one slot in my fuse box to solve my issue. Great people making a great product. Anyone complaining about the cost hasn't seen the time and spaghetti mess involved with wiring 8 ice cube relays to 8 switches, and the end result is bulky and nowhere near water proof.
    Attached Images Attached Images
  5. #185
    Nothing but a Thing IBeHeWhoIsJoshua's Avatar
    Join Date
    Mar 2013
    Location
    Camarillo, Ca
    Posts
    1,655
    Robert
    I probably missed it somewhere but will this allow me to have a 3-way switch for auxiliary rear lights? Come on when put in reverse with a manual override? Thanks...
  6. #186
    Fresh Catch
    Join Date
    Dec 2015
    Location
    new york city
    Posts
    4
    H
  7. #187
    Old Timer TrainWreck618's Avatar
    Join Date
    Oct 2015
    Location
    East of St. Louis
    Posts
    2,895
    Quote Originally Posted by hbarias View Post
    H
    Uhh... hi?
    Welcome to Wayalife..
  8. #188
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,943
    h
    [/url]
    i
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
