CharlieK
Recently changed my gears went from 4.56 to 4.88, and added lockers. I'm running 37's and no issues at all prior to gear change and addition of lockers. I have a Diablo Trinity, which I used to adjust axel ratio. First thru third no issues at all shifts normal. Fourth hangs up and shifts at 4100-4200 rpm, over really hangs up at shift around 5200 rpm. Spent all day on phone with Diablo, made sure tuner was up to date on downloads, then two different techs walked me through setting tire size,( Tape measure used to measure tires under weight 36 inches) and axel, still no change. Techs said issue had to be jeep or gear job not "THEIR TUNER". Transmission fluid looks good but going to change any way, verified gears are in fact 4.88.
Am I missing something?
First thought is to scrap Diablo and go with Procal or Flashpaq?
