Close
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. #21
    Fresh Catch cbetts's Avatar
    Join Date
    Apr 2014
    Location
    Torrance, CA
    Posts
    39
    Great writeup! I have come close to rolling my rig once (both driver's side tires came off the grond then dropped back down). Fortunately, there were some experienced wheelers that came to the rescue. I agree that getting the vehicle out of a predicament can be a lot more hazardous.
    Thanks for sharing!
    2006 Hummer H3 / Adventure / 5 Speed / No Bling
    2006 Pontiac Solstice
    2013 Kia Soul+
  2. #22
    Nothing but a Thing sean.m.adams33's Avatar
    Join Date
    May 2013
    Location
    Temecula
    Posts
    1,674
    Awesome sticky. I hope to never need it but I am glad it's here if I do...
  3. #23
    Fresh Catch Dieselcon's Avatar
    Join Date
    Jan 2012
    Location
    Australia
    Posts
    21
    Great article.... I was Lucky... once it rolled I shut the engine down....I was able to self recover with my winch and the Diesel engine started without issue... very Lucky. only damaged the rear passenger door... no windows brocken
  4. #24
    LOSER
    Join Date
    Aug 2013
    Location
    Loserville
    Posts
    172
    I know you didn't go into detail on the actual flipping the Jeep back over, but could you list some safe attaching points to the Jeep to keep people from doing more damage. In your pic you're attached to your EVO sliders. If one does not have sliders to attach to, what would you recommend next? Is the factory roll cage strong enough or will it bend? Obviously attaching to the frame would be good, but can list other points you have used, or seen others use, when a good slider like EVO's isn't an option.
  5. #25
    Knows a Thing or Two CharlieK's Avatar
    Join Date
    Jan 2014
    Location
    Tampa Florida
    Posts
    520
    Great post, thanks for taking the time to share it with us.
  6. #26
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    41,531
    Quote Originally Posted by T&ERun View Post
    As you seem to have already guess, hooking up to the frame is always optimal. If you don't have sliders to hook up to, you can loop a tree saver around the frame rail and that'll work too. If needed, hooking up to the roll cage will work as well but I would try to keep the attachment close to the B-pillar. I know some will give me shit for having one but, I also carry a short heavy duty chain with a standard hook on one end and a grab hook on the other. This allows me more options and so long as you're doing a nice, slow recovery and NOT jerking the rig around, it'll get the job done safely.
  7. #27
    Been Around the Block hogtyed's Avatar
    Join Date
    Jun 2014
    Location
    Floral City, Florida
    Posts
    432
    Thanks for the info; I made some typo repairs & will keep a copy in the toolbox. I hope I never have to use it but I would rather be safe then sorry.
  8. #28
    LOSER
    Join Date
    Aug 2013
    Location
    Loserville
    Posts
    172
    I agree on the chain. I've seen many trucks, tractors, bobcats recovered by a local towing/recovery company (a friend of mine's company). They always use chains unless there is nowhere to attach a hook (then they will use a strap which is usually 6"+ wide ). As Eddie stated, nice slow pulls only though...... Do not try to jerk or snatch with a chain!
  9. #29
    Hooked Ranger4011's Avatar
    Join Date
    Aug 2014
    Location
    Nunya
    Posts
    148
    Quote Originally Posted by GCM 2 View Post
    1 - shut the ignition off ASAP (even during the flop if possible). Prepare for fire, get the extinguishers handy.
    2 - evaluate injuries to people or pets. Attend to those first, forget about the stupid paint, metal and rubber damage.
    3 - recover the vehicle. This is as dangerous or more dangerous than the initial flop. This takes a lot of knowledge to right vehicle without causing further damage. The use of winch blocks is highly advisable to lessen the work on the winches doing the recovery, it also makes it much more controllable up until the point of gravity taking back over. Doing this type of recovery is exceptionally technical and actually is very helpful if you have had professional lessons/training.
    4 - once vehicle is righted, a seriously detailed assessment of the damage to the engine needs to be done before attempting to restart.
    5 - No need to drain the oil! That serves no other purpose other than to make the trail even more messy. However, you do need to pull the spark plugs to release any vacuum in the cylinders that might be keeping oil from returning back into the pan from the cylinders. Also pull the air filter to see if oil has made it up through the intake manifold and all the way to the filter element.
    6 - once it has been deemed safe to attempt an engine turn over, and with the plugs still out, crank the engine over to purge the cylinders of oil. Caution: this is super messy, oil is going to spray everywhere.
    7 - Once the cylinders seem dry of oil, clean all the spark plugs with brake cleaner really well. Reinstall spark plugs, check engine oil level on as flat a surface as possible and top off. Top off all other fluids too at this point.
    8 - start vehicle, prepare for lots of smoke......which will eventually go away. Now drive off trail.
    Caveat: it is possible that you may not have to pull plugs, but this is an advance technique to check if motor is hydro-locked, but I will not cover that here.
    For all you newer guys here on the forum, during the pre-run for the King of the Hammers 2013 race, my jeep was flopped on the first day of the run. Basically using the outline above, we recovered the jeep, finished pre-running that day and the next day too and then I drove the 435 miles from Johnson Valley back to Scottsdale, AZ
    You forgot one more thing
    Change your underwear.......,.,
  10. #30
    Been Around the Block Scoop315's Avatar
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    390
    The chain is a good idea, because if you have sharp edges on the frame, nylon straps can be damaged or cut, and you take the chance of losing tensile strength, or the whole load as you're pulling.
    Softeners for sharp edges should be used to reduce that risk.
    Just for reference...
    But, for wheeling, I'd keep some old 1/2" air hose cut up, with a longitudinal cut along the hose to fit over sharp edges. The best would be old fire hose, which might be hard to come by if you're not a fireman or work in a refinery or chemical company.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
