Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Rollover Recovery 101
  1. #1
    Oct 2011
    Carson City, NV
    52,271
    We all hope that it never happens but, when you play hard enough with your Jeep there's always a chance that you will flop or rollover it over on the trail. And, should that ever happen to you or one of your friends, the post below will help you to know what steps you should taken before, during and after the vehicle has been recovered. This information was provided by my good friend Greg and it's about as good as it gets.
    If you have any questions, please feel free to post them here as they would be more than welcome additions to the discussion and will be sure to help others as well.
  2. #2
    Old Timer GCM 2's Avatar
    Dec 2011
    Scottsdale, AZ
    3,917
    1 - shut the ignition off ASAP (even during the flop if possible). Prepare for fire, get the extinguishers handy.
    2 - evaluate injuries to people or pets. Attend to those first, forget about the stupid paint, metal and rubber damage.
    3 - recover the vehicle. This is as dangerous or more dangerous than the initial flop. This takes a lot of knowledge to right vehicle without causing further damage. The use of winch blocks is highly advisable to lessen the work on the winches doing the recovery, it also makes it much more controllable up until the point of gravity taking back over. Doing this type of recovery is exceptionally technical and actually is very helpful if you have had professional lessons/training.
    4 - once vehicle is righted, a seriously detailed assessment of the damage to the engine needs to be done before attempting to restart.
    5 - No need to drain the oil! That serves no other purpose other than to make the trail even more messy. However, you do need to pull the spark plugs to release any vacuum in the cylinders that might be keeping oil from returning back into the pan from the cylinders. Also pull the air filter to see if oil has made it up through the intake manifold and all the way to the filter element.
    6 - once it has been deemed safe to attempt an engine turn over, and with the plugs still out, crank the engine over to purge the cylinders of oil. Caution: this is super messy, oil is going to spray everywhere.
    7 - Once the cylinders seem dry of oil, clean all the spark plugs with brake cleaner really well. Reinstall spark plugs, check engine oil level on as flat a surface as possible and top off. Top off all other fluids too at this point.
    8 - start vehicle, prepare for lots of smoke......which will eventually go away. Now drive off trail.
    Caveat: it is possible that you may not have to pull plugs, but this is an advance technique to check if motor is hydro-locked, but I will not cover that here.
    For all you newer guys here on the forum, during the pre-run for the King of the Hammers 2013 race, my jeep was flopped on the first day of the run. Basically using the outline above, we recovered the jeep, finished pre-running that day and the next day too and then I drove the 435 miles from Johnson Valley back to Scottsdale, AZ
    Attached Images Attached Images
    2009 Black Rubicon Unlimited
    EVO Long Arm w/Envy Links
    EVO Front Double Throw Down
    EVO Lever Rear w/Double Throw Down
    Dynatrac Pro Rock 60's f/r
    PSC hydraulic ram assist
    Mastercraft Baja RS seats
    J.E. Reel 1350 drive shafts
    ATX Slab wheels
    40" Nitto Mud Grapplers
  3. #3
    Token East Coast Guy MR.Ty's Avatar
    Apr 2014
    South East Georgia
    6,415
    Wow thank you for that info and background story.
    So I am guessing it is a good idea to add things to my tool bag like: Oil (to top off with), air filter, something to pull the spark plugs with, kitty litter to clean up the oil with. Edit: and a fire extinguisher.
    More noob questions: Do how do you crank the engine over....
    Loading please wait....
    2014 JKUR "Stumps"
  4. #4
    Dec 2011
    Scottsdale, AZ
    3,917
    Quote Originally Posted by MR.Ty View Post
    Well, the level of wheeling we do out here in the west is often pretty extreme and if everyone carries a few extra quarts of oil, water/antifreeze, powersteering fluid, diff fluid and a decent selection of tools, there will usually be more than enough supplies to fix someone who had a bad day.
    So yes, you are definitely a noob Now this is pretty technical and I'm guessing you mean "crank the engine over" when the plugs are out. I will see if I can dumb this down enough.....insert the key into the ignition and try to start the vehicle! That simple, it won't start because there are no plugs to help compression build and then fire the compressed mixture of fuel and air, so the engine just spins freely. Too easy .
    ATX Slab wheels
  5. #5
    Apr 2014
    South East Georgia
    6,415
    Quote Originally Posted by GCM 2 View Post
    So yes, you are definitely a noob Now this is pretty technical and I'm guessing you mean "crank the engine over" when the plugs are out. I will see if I can dumb this down enough.....insert the key into the ignition and try to start the vehicle! That simple, it won't start because there are no plugs to help compression build and the fire the compressed mixture of fuel and air, so the engine just spins freely. Too easy .
    I dunno... that sounds like a really advanced maneuver. Nothing about that seems easy.
    Serious note: Thank you for taking the time to answer my questions. :thumbup:
    2014 JKUR "Stumps"
  6. #6
    Living the WAYALIFE JAGS's Avatar
    Aug 2012
    SoCal
    11,088
    KFirst-
    Second-
    Three-
    Four-
    Five-
    Six-
    Seven-
    Eight-
    Caveat:
    That is an awesome step by step. Thank for that Greg. I just printed out the post and am going to throw it in with my trail tools. I hope to never need it, but certainly helpful to have on the trail for myself or to help others.
    I think I may consider lifting my Jeep. Or not.
    The Evolution of ENVY
  7. #7
    Dec 2011
    Scottsdale, AZ
    3,917
    You got it Mr. Ty, no problems brother
    ATX Slab wheels
  8. #8
    Hooked Munday's Avatar
    Dec 2011
    Red Deer,AB
    100
    Good question Mr. Ty ....... Great info GCM2.
  9. #9
    Hooked spicoli's Avatar
    May 2014
    Seattle, WA
    164
    KFirst- shut the ignition off ASAP (even during the flop if possible). Prepare for fire, get the extinguishers handy.
    Second- evaluate injuries to people or pets. Attend to those first, forget about the stupid paint, metal and rubber damage.
    Three- recover the vehicle. This is as dangerous or more dangerous than the initial flop. This takes a lot of knowledge to right vehicle without causing further damage. The use of winch blocks is highly advisable to lessen the work on the winches doing the recovery, it also makes it much more controllable up until the point of gravity taking back over. Doing this type of recovery is exceptionally technical and actually is very helpful if you have had professional lessons/training.
    Four- once vehicle is righted, a seriously detailed assessment of the damage to the engine needs to be done before attempting to restart.
    Five- No need to drain the oil! That serves no other purpose other than to make the trail even more messy. However, you do need to pull the spark plugs to release any vacuum in the cylinders that might be keeping oil from returning back into the pan from the cylinders. Also pull the air filter to see if oil has made it up through the intake manifold and all the way to the filter element.
    Six- once it has been deemed safe to attempt an engine turn over, and with the plugs still out, crank the engine over to purge the cylinders of oil. Caution: this is super messy, oil is going to spray everywhere.
    Seven- Once the cylinders seem dry of oil, clean all the spark plugs with brake cleaner really well. Reinstall spark plugs, check engine oil level on as flat a surface as possible and top off. Top off all other fluids too at this point.
    Eight- start vehicle, prepare for lots of smoke......which will eventually go away. Now drive off trail.
    Wow great info. Thanks. I definitely need to add a couple things to my trail kit.
  10. #10
    Oct 2011
    Carson City, NV
    52,271
    With much appreciate to Greg for taking the time to share his well written recovery post, I have just made this information a Recover 101 sticky thread.
