Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Maximus-3 Winch Plate and Zeon 10S install on 10A/X/HR Bumper
  1. #1
    Nothing but a Thing H8ROADS's Avatar
    Join Date
    Nov 2012
    Location
    Denver, CO
    Posts
    1,403
    Lightbulb Maximus-3 Winch Plate and Zeon 10S install on 10A/X/HR Bumper
    I wanted to take advantage of the money invested into the "stock" bumpers on my Hard Rock edition, so I decided to go with the Maximus-3 winch plate which is a bit cheaper than the Mopar variety alongside the Zeon 10S winch. I also added a Maximus-3 license plate holder that mounts to the
    hawse fairlead.
    Pre-install
    The winch plate kit and license plate kit.
    Remove the 7 15mm bolts that keep the skid plate attached.
    Remove all the bolts that hold the winch filler plate, as well as the plastic filler plate.
    Unplug the fog lights
    Attachment 113812
    Remove the 8 18mm bolts that hold the bumper onto the frame on both sides.
    Attachment 113810
    The bumper removed
    Install the pump relocation bracket to the winch plate with the supplied bolts.
    Cut the existing pump bracket off with a 3" cutoff wheel. Then paint the grind to prevent rust. Slide the winch plate in and use any bolts as a temporary support in the front - do not tighten.
    Secure the pump to the relocation bracket. Secure the rear bolts of the winch plate.
    Test fit the winch into the plate.
    Run the wiring
    After confirming the winch is centered and the wiring is good and working, tighten the rear winch plate bolts. Bolt the winch to the winch plate. You can go ahead and spool the winch line on at this point.
    Now, back to the bumper! Remove the plastic cover in the middle of the bumper and toss it.
    Measured about 2" from the middle of the left holes, and created a pilot hole
    Using a 1-7/8" bi-metal hole bit, I created the hole to match the winch fairlead opening. You'll then use a 3" cutoff wheel to chop off the metal in between the hole and the fairlead hole.
    The new fairlead hole after cut out, filed down, and painted.
    After everything is dried, you mount the center winch plate, hawse fairlead, and license plate bracket all to the front of the bumper with the supplied bolts. You then bolt up the bumper with the 8 18mm bolts again, and that's about it!
    The final product!
    With the optional license plate mount.
    A few notes: When you cut off the pump bracket, do it better than I did - it becomes a bit of pain in the ass to tighten the frame bolts for the bumper if you have it sticking out even a little like I did. I finally got the job done but not without a lot of tinkering. Also, good luck getting the synthetic rope pulled through with the supplied zip tie. I went through many before finally getting it through.
    Overall, not too bad - it took me 2 afternoons by myself to complete, but that was with several interruptions. I like the results! Any questions, lemme know!
    /VVVVVVVVVV\ Denver, CO - Mile High Wayalife! /VVVVVVVVVVV\
    Denver Mile High Meetup Thread | H8ROADS Build Thread
    Follow me on twitter @jackwmc4
  2. #2
    Token East Coast Guy MR.Ty's Avatar
    Join Date
    Apr 2014
    Location
    South East Georgia
    Posts
    6,219
    I like it! Looks really clean with the hook hidden behind your front licence plate.
    2014 JKUR "Stumps"
  3. #3
    Nothing but a Thing sean.m.adams33's Avatar
    Join Date
    May 2013
    Location
    Temecula
    Posts
    1,674
    Nicely done. Clean stock look.
  4. #4
    Knows a Thing or Two hbkid22's Avatar
    Join Date
    Aug 2014
    Location
    Fort Collins, CO
    Posts
    802
    Looks good! Can't wait to see what you have planned.
  5. #5
    Knows a Thing or Two Speeddmn's Avatar
    Join Date
    May 2012
    Location
    Hill AFB, UT
    Posts
    515
    Really good looking combo!
    ** 2010 Unlimited Rubicon ** Gone but not forgotten...
    ** 2016 Renegade Trailhawk**
  6. #6
    Knows a Thing or Two CharlieK's Avatar
    Join Date
    Jan 2014
    Location
    Tampa Florida
    Posts
    520
    Really clean looking. Great job
  7. #7
    Hooked CanadianJK's Avatar
    Join Date
    Jul 2014
    Location
    Canada
    Posts
    120
    Like mine off centre. Looks good though. How sturdy is the license plate mount? Eventually when I move I'll need a front plate.
  8. #8
    Knows a Thing or Two Wardell's Avatar
    Join Date
    Sep 2014
    Location
    Yellowknife, Northwest Territories, Canada
    Posts
    539
    Thanks for posting this up. That's a really slick looking setup, and the install looks pretty straightforward too. Can't wait to mount one of these in my Jeep, though I'll probably have to wait until spring.
  9. #9
    Nothing but a Thing Clem319's Avatar
    Join Date
    Jul 2014
    Location
    Bakersfield, CA
    Posts
    1,152
    Good work. Looks great.
  10. #10
    Knows a Thing or Two SFNick's Avatar
    Join Date
    Jan 2014
    Location
    Arkansas
    Posts
    599
    Looks badass! Nice job.
    MADE IN AMERICA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
