Page 34 of 37 FirstFirst ... 243233343536 ... LastLast
Results 331 to 340 of 363
Thread: wschilawski's JKU Build
  1. #331
    Nothing but a Thing TrailHunter's Avatar
    Apr 2016
    SoCal
    2,185
    Quote Originally Posted by wschilawski View Post
    Just a quick update on the Trigger - we were putting our son to bed when I saw this glowing coming from the driveway. Nope, not aliens, but my light bar. Somehow it got turned on, same thing happened with my a-pillar lights at work the other day. I reset the remote to a different code but it kept happening.
    I'm picking up a new control box tonight and will be running the trigger wire directly to the fuse box using a fuse splice (to the heated seat location). Hopefully it was just a bad box; will update once it's installed.
    Also picking up some used Smittybilt XRC fender flares tonight so I'll post photos of those later on as well.
    Until then, Jeep on!
    That’s weird.... maybe the neighbors kid downloaded the app and he’s messin with ya... lol... hope you get that resolved.
  2. #332
    Been Around the Block wschilawski's Avatar
    Jan 2015
    WI
    366
    Well I switched out with a new Trigger Controller but had the same problem - people kept flashing their brights and then I realized the lightbar turned on. I'll be swapping out with the 6-rocker switch system from Rough Country next month; decided to get away from all the bluetooth options and run wires direct.
    The Trigger was a neat design, just didn't work for me (checked wiring/re-checked wiring/checked connections).
    3.5" MC | 37x12.5 Mastercraft MXT
    Double Deuce Build Thread
  3. #333
    Old Timer BaddestCross's Avatar
    Aug 2016
    Palmdale, CA
    2,941
    I decided against that system for fear of that exact issue. Good idea, but nothing more reliable than a good one fashioned hard-wire. Sorry you had issues. 🍻
    Build Thread: Adventures with Fiona
    '08 JKR Rescue Green 2-Door
  4. #334
    Jan 2015
    WI
    366
    Quote Originally Posted by BaddestCross View Post
    Definitely worth a shot to see how it worked, just not for me. Hard-wire it is!
    I'll be putting some new shocks in this weekend; went with the Rocksports through MetalCloak. I've heard good things about this for a budget shock so I figured I'd try them out and get rid of the Rough Country ones that are in there now. These were a hand-me-down when I wanted to change out the Bilsteins.
    A buddy just opened a shop here in Green Bay so it will be nice to work indoors on a lift
  5. #335
    Nothing but a Thing AZ Explorer's Avatar
    Feb 2017
    San Tan Valley, AZ
    1,689
    There's no topping being able to work on your Jeep in those conditions.
  6. #336
    Jan 2015
    WI
    366
    Spent some time Saturday putting 10+ coats of paint on the new red RockSport shocks along with testing the travel out. At full flex, I'm at 33" between the floor and bottom of tire. And there's an axle seal that needs to be replaced as well
    We then went out near Lakewood on Sunday to play around a bit. Ends up new u-joints are needed.
  7. #337
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    23,612
    Access to a paint booth. Nice.
  8. #338
    Jan 2015
    WI
    366
    New meaning to the whole "friends with benefits" phrase
  9. #339
    Jan 2015
    WI
    366
    Ordered new axle seals, u-joints, and EVO rear shock skids this week for another shop day Saturday. With the snow starting to fall, 4WD has been engaged a few times. I've been getting some grinding/ticking noise while in 4WD at slower speeds. We're going to changeout the u-joints and possibly the front driveshaft to try pinpointing the problem. Will do a transfer case fluid change also while it's on the lift.
  10. #340
    Jan 2015
    WI
    366
    Spent another day at the shop on Saturday; replaced inner axle seals, axle u-joints, installed EVO rear shock skids, and removed the outer axle seals (trapped all kinds of crap in the axle tubes - go figure). Still have a clicking up front so we'll be swapping out drive shafts on Wednesday to try and pinpoint what's going on.
    Sunday we played in the snow again in Lakewood with a larger group - had a blast!
