Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Dynatrac Prosteer Ball Joints Install
  1. #21
    Hooked Hangemhigh1's Avatar
    Join Date
    Feb 2013
    Location
    Las Vegas , nv.
    Posts
    163
    Quote Originally Posted by USMC Wrangler View Post
    Other than what the others have mentioned, are you kind of tilting the shaft up a bit to make sure the splines clear the seal? Iíve left my guides in place the two times Iíve pulled mine but still had to wiggle the shaft up and down a bit to get them to seat.
    Thank you for your feedback. Iím trying to figure out what is half way down the tube. My guess was that its the plastic axle guides. Pulled out 2, i guess there could be more? EB3C1B22-F756-4918-B036-383B05D427FD.jpg
  2. #22
    Old Timer USMC Wrangler's Avatar
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    4,066
    Quote Originally Posted by Hangemhigh1 View Post
    Honestly, Iím not sure. Iíve pulled my front shafts twice and rears once. I didnít run into the problem you are experiencing. Mines a sport so I know slightly different.
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    DIY trail/tube door build http://wayalife.com/showthread.php?24449-My-DIY-Doors
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
  3. #23
    Join Date
    Feb 2013
    Location
    Las Vegas , nv.
    Posts
    163
    Thank you all again for all the feedback. It was very helpful. I Started working on installing the shaft again and again there was an obstruction. The end result was that the ring that was at the center fo the axle tube, was part of the shaft seal. Having seen that and seeing the write up on the shaft seal install, I opted for taking my Jeep to Adams Driveshaft and letting them do this work. This is above my skill set (yes Iím a chicken)
  4. #24
    Join Date
    Feb 2013
    Location
    Las Vegas , nv.
    Posts
    163
    More questions.
    I put everything back together, on both the passenger and the driver side. The ball joints came off easy, the new Dynatrac ball joints went on easy. I still had to fight the axle on the driver side to remove it. The same thing happened on the driver side. Part of the seal followed the shaft out of the tube. As I mentioned, I’m taking my rig to a shop to get new seals installed. The distance is 21 miles. I’m only driving it that day, and leaving it parked till then. Does anyone know if there is the potential for the diff. fluid to spill out of the axle tubes in the time it will take to get to the shop 21 miles away? I live in Las Vegas and it’s still cool during the a.m. if that makes a difference. Has anyone run into this issue? Thank you in advance for any insight.
    Last edited by Hangemhigh1; 03-18-2019 at 06:22 PM. Reason: Corrected some of the wording to make it more understandable.
  5. #25
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,676
    As I mentioned, Iím taking my rig to a shop to get new seals installed. The distance is 21 miles. Iím only driving it that day, and leaving it parked till then. Does anyone know if there is the potential for the diff. fluid to spill out of the axle tubes in that time? I live in Las Vegas and itís still cool during the a.m. if that makes a difference. Has anyone run into this issue? Thank you in advance for any insight.
    Shove a good sized rag in the tube and you'll be fine.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  6. #26
    Join Date
    Feb 2013
    Location
    Las Vegas , nv.
    Posts
    163
    Quote Originally Posted by WJCO View Post
    The axle shaft is in the tube. The whole assembly is completely put together. I was thinking of leaving the axle shafts out, but I wanted the shop too see the whole thing completely assembled.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
