Results 1 to 8 of 8
Thread: Need help on lift and tire plan
  1. #1
    Fresh Catch
    Join Date
    Dec 2014
    Location
    Charlotte, NC
    Posts
    6
    Hey guys im fairly new to jeepin and im hoping to get a lift and tires on my jk in the spring. The plan right now is to get 33x12.5r15 tires (probably hankok m/ts) and the aev 2 inch spacer lift. I then plan on getting bilsteen shocks whenever i can afford them after the tires and lift. I want to get the 2" longer shocks and then get 2" longer springs. Is this possible and does it make sense. Im in college and make minimum wage so im not trying to blow out the bank account but i know jeeps arnt cheap. My jeep is a DD with the occasional trail riding so i dont want to get too crazy and kill my mpg but i want better performance offroad and onnroad. i want more articulation in my suspension but cant afford a 1000 lift on top of 1500 tires and rims. Am i missing anything in my plan? do i need to get anything else with this? I have a 2012 wrangler sport 2 door. Thanks
  2. #2
    Join Date
    Feb 2015
    Location
    East Coast
    Posts
    154
    I would go with just the spacers along with the wheels and tires. From what it sounds you'll be doing, this should probably be enough.
  3. #3
    Old Timer JKRay's Avatar
    Join Date
    Oct 2011
    Location
    Bakersfield, CA
    Posts
    3,206
    Welcome to Wayalife!!
    Quote Originally Posted by 05Jeeper View Post
    I agree the stock springs & shocks can handle it for a while. 😎
  4. #4
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,742
    Quote Originally Posted by rallison96 View Post
    you don't have any info about your Jeep but as soon as you lift and put on those M/Ts you will kill your mileage.
    I'd keep it stock and wheel it as is - just pick good lines when off-road.
    a 2" lift isn't going to make so great a difference in performance and may make it worse as you change the suspension.
    IMO, you being in college, I'd save my money for future expenses and enjoy your Jeep as it is.
  5. #5
    Been Around the Block jkuone's Avatar
    Join Date
    Dec 2013
    Location
    Colorado
    Posts
    380
    If you want to to a coil spacer lift check out Rancho, good kits and great prices. Don't waste your money
    On AEV ! To expensive.
    13 JKU Auto-JKS 3 1/2" lift| Currie Adj control arms | JE Reel FR Drive Shaft | synergy Tie Rod, Drag Link| Currie Antirock | Warn 9.5 cti winch |bumpers ! Poison Spyder /Expedition one |
    EVO Sliders | Dynatrac diff covers | Fuel Anza Wheels, Nitto 35's| ARB locker rear / G2 Core 44 frt axle, 35 spline ARB Locker, RCV axle shafts,| G2 4:56 gears, Chromoly axle shafts | trail Ready limiting straps FR / Rockhard engine/ tranny skid, Rockhard gas tank skid, Ridgid A pillar spots,
  6. #6
    Knows a Thing or Two Kalums's Avatar
    Join Date
    Jan 2015
    Location
    AZ
    Posts
    926
    Just to throw it out there alot of guys w/ 2 doors just get good 4 door front and rear springs supposedly gives you about an inch lift and you can get a set (front and rears) for 100$ or so, but I agree with a couple of the others remember your Jeep is quite capable with out a lift and being in college ain't cheap. Believe me, as anyone on here can confirm it is HARD to wait (especially for Jeep mods) but in the long run..... I think you would be happier.
  7. #7
    Nothing but a Thing JK LYF's Avatar
    Join Date
    Sep 2014
    Location
    Southern California
    Posts
    1,014
    Quote Originally Posted by Kalums View Post
    Agreed. Find out what springs you have now. Each spring has a number attached. Then compare the numbers to a 4 door rubicon spring set. If the numbers on the 4 door spring set are higher than what you have (for example 18 front and 59 rear) then you may want to think about swapping the springs. It may give you an inch and a half lift while keeping everything else stock. I placed 18/60 springs on my 2 door and got about 2 inches of lift. If you need to level it out in front put a 3/4 inch spacer above springs. This will give you a clean look with a little extra clearance while keeping everything nearly stock and at an affordable price. You can pick up 4 springs for about 100 bucks. That's what I'm running now until I get my lift. Hope this helps. Good luck.
    2008 2DR RED ROCK X
  8. #8
    Old Timer Rccrwlr's Avatar
    Join Date
    Mar 2013
    Location
    Here
    Posts
    2,672
    First. Welcome to WayALife. Stop by the give us a wave section and tell us about your rig.
    Second you should be able to fit 33" on a minor lift and if the 4 door spring can get you there they can be picked up for cheap
    Check this link out for a few basic items as well
    http://wayalife.com/showthread.php?2...ep-JK-Wrangler
    Enjoy the WAL
    Looks like I'm locked out. Why?
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
