A couple of questions.....
Kalums
So 2 questions actually
1) is there anyway to "tint" the rear soft top windows darker? (I personally don't think so but am not 100% sure)
2) will installing the EVO Leveling kit and disconnects eliminate my tire rub on the sway bar w/stock Moab rims and 33s? Or will I still need spacers?
cozdude
Guy with a Red 2-Door
2) will installing the EVO Leveling kit and discounts eliminate my tire rub on the sway bar w/stock Moab rims and 33s? Or will I still need spacers?
For the tint I can't help you.
For tires you may need spacers at full lock. I would put them on and run them then if you find out you need them then you can add them on later.
catahoula
You can get replacement windows that are tinted for your factory top. Would look nicer. I do not think there are any tint for these kind of window.
Kalums
I have the "tinted" soft top windows but they are 35% I was looking to go darker ( 25-15 vlt)
