JRied
Try to make this short. Bought my jeep and when I hit a small hole on the road at speed I hear a what sounds like metal on metal clank (loud 1 time, not a rattle) coming from what sounds like the steering wheel area but way down it may be in the engine Bay Area on other side of fire Wall idk. Just installed my new lift and like an idiot I drilled out my drag link flip kit knuckle to 7/8 instead of 13/16. So i drove it around for a cpl days loose (tightened all the way down but there's still play in the knuckle because the sleeve is too small for the hole so that's why I say loose) while I waited for the new 7/8 insert to run the new drag link currectly. During that 5-6 day period I hit the same hole and SILENCE, no sound. I'm happy. Received the new correct size knuckle insert and installed the flipped drag link correctly where it's no longer a tad loose in the hole and CLANK! sounds back when I hit the hole. Wtf am I hearing it drives me crazy. Mainly when right tire alone absorbs the impact. Is it sector shaft area? Idk what to look for and its pissing me off
