Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
Thread: Flashcal driver, what am I doing wrong?
  1. #21
    King Retard
    Join Date
    Jul 2015
    Location
    Posts
    22
    Quote Originally Posted by tharb5111 View Post
    Their new tire pressure setting is now on at stock setting or all off and set to zero. No more sliding scale for you to set your own pressure. They said it no longer works in 2013 or 14 models so it's either all on or all off. Disappointing but at least it gets rid of the warning lights. Those were annoying.
    That's a bummer. I just received my FlashCal yesterday. The TPMS threshold was a feature I planned on using. Disappointing.
    Also, I couldn't get the drivers to work on my Win7 laptop. Using my Win8 laptop solved the issue.
  2. #22
    The Original Smartass piginajeep's Avatar
    Join Date
    Oct 2011
    Location
    Bear Valley Springs
    Posts
    10,834
    Quote Originally Posted by Flexy View Post
    I can't get mine to connect on win8.
    2012 JK8
    1958 FC170 (Jeep Forward Control)
    1953 M38A1
  3. #23
    Been Around the Block
    Join Date
    Apr 2015
    Location
    Prosper, Texas
    Posts
    312
    Quote Originally Posted by piginajeep View Post
    You can't use the web address they list in instructions. I called them after having same issue and they sent me to www.fusionupdate.com. click on download spark updater and your golden. They really need to update the directions for install.
  4. #24
    Join Date
    Oct 2011
    Location
    Bear Valley Springs
    Posts
    10,834
    I did download the spark. It will not find the programmer.
    2012 JK8
    1953 M38A1
  5. #25
    Been Around the Block shadowpaige64507's Avatar
    Join Date
    Feb 2015
    Location
    United States
    Posts
    422
    Only way I got mine to work was plugging the programmer in.
    Control Panel
    Device Manager
    Then look for something called SuperFlash (I can't remember what it was called, but it should be obvious.
    After you right click on that you can search for Driver.
    Mine took a long time but found it when I left the computer open all night.
    Hope that helps.
  6. #26
    Living the WAYALIFE JAGS's Avatar
    Join Date
    Aug 2012
    Location
    SoCal
    Posts
    10,914
    I tried on two different PCs and never could get it to work. Ended up selling the damn thing and going pro cal.
    I think I may consider lifting my Jeep. Or not.
    The Evolution of ENVY
  7. #27
    Join Date
    Oct 2014
    Location
    DFW, TX
    Posts
    424
    I still havent got it to work, and I am close to doing the same. Or I could just buy a set of TPMS sensors, but then, I would rather be able to turn it off. I like the code reader and ability to lock the diffs in 4-hi, so its a bit of a debate right now. I might try to borrow another laptop to play with, though.
  8. #28
    Knows a Thing or Two
    Join Date
    Oct 2013
    Location
    SoCal
    Posts
    577
    THIS is why we use AEV ProCals...
  9. #29
    Nothing but a Thing NevadaZielmeister's Avatar
    Join Date
    Jul 2015
    Location
    Reno, NV
    Posts
    1,170
    Quote Originally Posted by drew@offroadevolution View Post
    This is what will go in my soon to be 2016 Jeep as well. Thank you Drew for the always sound advice.
    RubySky's Build:
    EVO Double Throw Down Front and Rear suspension with bypass system and EVO Lever
    EVO Extreme High Clearance Long Arm Upgrade
    Dynatrac ProRock 44 Front Axle with Pro Steer Ball Joints, G2 35 Spline Placer Gold Axles, ProGrip Brakes
    Dynatrac ProRock XD60 rear axle, full float with 5.38 gearing
    JE Reel 1350 drive shafts
    EVO Pro-Tek Skid Plate System
    PSC Extreme Duty Cylinder Steering Assist kit
    EVO Rear RockStops with King Air Bumps
    Nitto Trail Grapplers at 37x12.50x17
  10. #30
    Join Date
    Feb 2015
    Location
    United States
    Posts
    422
    I like the flashcal because it reads the codes WITH a description of what the code means.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
