Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
Thread: What's the smoothest lift out there?
  1. #41
    Knows a Thing or Two NV375's Avatar
    Join Date
    Jan 2014
    Location
    Nevada
    Posts
    785
    Congratulations. Post up some pics when you get it installed.
  2. #42
    Knows a Thing or Two JakeJK's Avatar
    Join Date
    Mar 2015
    Location
    Alabama
    Posts
    922
    Quote Originally Posted by NV375 View Post
    Will do I'll be running stock tires until I can afford some 35s but until then I will enjoy my newly heightened jeep
  3. #43
    Fresh Catch
    Join Date
    May 2014
    Location
    East Tennessee
    Posts
    6
    Good evening guys,
    If I am changing out from a Teraflex BB with shock adapters is the only thing I would need is the 3" Evo Plush ride coils and shocks (Fox 2.0s)? i currently run 285 Duratracs with open fenders so no clearance issues. Will be going to 35s in the future.
    What advantage is the controls going to give for a DD, limited trails for now? Thanks!
  4. #44
    Nothing but a Thing trailless's Avatar
    Join Date
    Apr 2013
    Location
    Atlanta, Georgia
    Posts
    1,148
    Quote Originally Posted by Rocs2Wavs View Post
    Good evening guys,
    If I were doing what you're doing.
    Get the front lower control arms. A drag link flip, extended bump stops, longer brake lines and an exhaust spacer/ new drive shaft.
  5. #45
    Fresh Catch
    Join Date
    May 2014
    Location
    East Tennessee
    Posts
    6
    Quote Originally Posted by trailless View Post
    That sounds like it is shy of the enforcer set up. Drive shaft? Is that to account for the increased angle of the dangle? Are the 3" coils is going to take it much higher that the BB is now at 2.5 (+1/2 inch) ? Wondering if the Bumpstops on the BB wouldn't suffice as well? Genuinely curious not be argumentative.
  6. #46
    Join Date
    Oct 2014
    Location
    Richmond, Ky
    Posts
    4,105
    yes on the drive shaft. Even at 2.5 your front driveshaft will be at a steep constant angle. Look under your jeep at the output of the tcase where it bolts to the front shaft. They arent meant to run at that angle 24/7.
    Bump stops can be hit or miss but they are generally the same as your lift height. The purpose is to prevent shocks from bottoming out so whatever height that ends up being.
  7. #47
    Join Date
    Mar 2015
    Location
    Alabama
    Posts
    922
    ImageUploadedByWAYALIFE1439041443.886517.jpgImageUploadedByWAYALIFE1439041459.521813.jpg
    Needs tires but I'll enjoy it for now
  8. #48
    Join Date
    Jan 2014
    Location
    Nevada
    Posts
    785
    Looking good and tires will look even better.
  9. #49
    Join Date
    Mar 2015
    Location
    Alabama
    Posts
    922
    ImageUploadedByWAYALIFE1457028043.232127.jpgImageUploadedByWAYALIFE1457028053.188380.jpg
  10. #50
    Been Around the Block whispike's Avatar
    Join Date
    Oct 2011
    Location
    So Cal
    Posts
    258
    Quote Originally Posted by JakeJK View Post
    Okay that's good to know, do yall know if the newer version BFG all terrains or the general grabber provide good rides, or have any input on the smoothest all terrain/mud terrain tires
    I have the General Grabbers and they've been great offroad. They are on the stiff side on-road but not too noisy. I would get them again, but when I move up to 37's on my next set of tires I'll probably go with Nitto's or Toyo's.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
