Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Switch-Pros switches mounted to Daystar dash switch panel?
  1. #1
    Fresh Catch jared181920's Avatar
    Join Date
    Feb 2013
    Location
    Canada
    Posts
    9
    Hi guys,
    I've been throwing around the idea of getting the Switch-Pros switching system, but I've been a bit unsure of the best place to mount it. I very much like what Eddie did with his old switch module on Moby, using the Daystar mount.
    So I got to wondering if something like that would be feasible with the Switch-Pro panel as well. I was wondering if anyone with the Daystar panel would be able to measure the width and height of the area where the switches typically go to give me an idea if that could work. Based off of boardsurfer's posts here it looks like the Switch-Pros module is about 4 1/2" x 2", and from the Daystar pictures it looks like that should fit on their panel, but wanted to verify first before I pull the trigger on that.
    My one thought is that you could use some screws and screw the unit right to the front of the Daystar unit, or possibly bend the little screw tabs on the side backwards, and then just cut little notches in the Daystar panel to pop it in there. It could then be fastened in using screws or some kind of adhesive or something perhaps, to make it look a bit cleaner.
    Anywho, thanks in advance to anyone who can provide measurements of the Daystar unit, much appreciated!
  2. #2
    Been Around the Block LeighP's Avatar
    Join Date
    Aug 2014
    Location
    Sydney, Australia
    Posts
    292
    I made a small box/panel up that sits below the outboard dash vent...its about the size you mention. Pretty straight forward to make, and it fits nicely. Reverse the pic for LHD JK's, lol.....
    Theres plenty of room behind here to access for fasteners and wiring.
    If I need more switches, I'm thinking I could make another panel to fit the rounded section of the centre dash binnacle, in front of the dash storage tray.....
  3. #3
    Fresh Catch Southpaw1746's Avatar
    Join Date
    Nov 2014
    Location
    New York
    Posts
    19
    Quote Originally Posted by LeighP View Post
    Great job! Any chance you have photos of the installation?
  4. #4
    Nothing but a Thing boardsurfer's Avatar
    Join Date
    Jan 2015
    Location
    Denver
    Posts
    1,820
    I wouldn't count on bending the tabs on the switch-pro. They are pretty stout and part of the whole back piece.
  5. #5
    Join Date
    Jan 2015
    Location
    Denver
    Posts
    1,820
    Quote Originally Posted by Southpaw1746 View Post
    If you flip the included bracket upside down on the back of the switch panel, it will fit perfectly on that spot LeighP posted and will be angled out nicely for a good visual. Problem is, from my driving position, the steering wheel completely blocks that spot for me and I couldnt see it at all. I went through several spots to mount before I decided on front and center.
  6. #6
    Join Date
    Feb 2013
    Location
    Canada
    Posts
    9
    I definitely second this! Curious how you attached the module to the dash though. Any chance we could get a side shot?
  7. #7
    Join Date
    Feb 2013
    Location
    Canada
    Posts
    9
    Quote Originally Posted by boardsurfer View Post
    Hmm, I do kind of like that! Although I'm not sure if I can make it work as I have my window switches there. I also was thinking that if the module was mounted on the bracket you could maybe fit it just above the AC knob?
    My other thought was perhaps on the bracket, down on the base of the center console directly in front of the shifter. Kind of where the Daystar panel would sit, but rather than mounting it on that location, mounting it on the base of the console where the little rubber tray is.
    Kind of in this area...
    Just not quite sure if there's enough height there for the module on the bracket.
  8. #8
    Join Date
    Jan 2015
    Location
    Denver
    Posts
    1,820
    If you have a regular business card handy you can get an idea. They're both 2 inches tall. I think that's a good spot though.
  9. #9
    Addict jeeeep's Avatar
    Join Date
    Oct 2011
    Location
    Tx
    Posts
    5,742
    got my switch-pro, need to figure out where I'm going to install it as well. I'd like it out of sight
  10. #10
    Hooked BigPrince's Avatar
    Join Date
    Aug 2014
    Location
    GA
    Posts
    210
    Just FYI I mounted mine to my cage dash bar with zip ties to see if liked it up there before doing anything more permanent.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
