Results 1 to 5 of 5
Thread: swaybar end links squeaking
  1. #1
    Knows a Thing or Two Wethy's Avatar
    Join Date
    May 2014
    Location
    Ontario
    Posts
    761
    as the title states i was going to swap my 2.5" quick discos into my unlifted jk to use on an up coming run. i however noticed that with no lift it seems like it'd rub the tubes coming through the frame. so i didnt. i reinstalled the stock links and now it squeaks like a banshee! how do i remedy this? it was on level ground when i tightened them up. maybe i over tightened them? i didnt have a torque wrench handy when i tightened em so i just cranked em down to what they felt like when i broke em loose. any suggestions?
    drives fine. just squeaks :S
  2. #2
    Fresh Catch TomJK's Avatar
    Join Date
    Mar 2015
    Location
    South Bend, IN
    Posts
    42
    Eh just take em off for good... Makes city driving more exciting!
    But if that's not your particular kettle of fish... Perhaps try spraying a little wd40 on the ends? I don't think that could hurt. Or maybe disconnect them again, and make sure the surfaces are clean. I had a squeaking problem after putting in a new link. I actually needed to tighten it more.
  3. #3
    Join Date
    Oct 2012
    Location
    SoCal
    Posts
    32,799
    Quote Originally Posted by Wethy View Post
    Your axle is not centered if it rubs those tubes. Not a big deal just cut the end of the tube.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37” Trail Grapplers
    -Rock Krawler 2.5” Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40” Trail grapplers
    -KMC Machetes
    -JE Reel 1410/1350 Driveshafts
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  4. #4
    Join Date
    May 2014
    Location
    Ontario
    Posts
    761
    Quote Originally Posted by OverlanderJK View Post
    Ha ha it doesnt rub now the sway bar just barely misses both sides of the tube. I guess it could need to be tightened more maybe cant get a torque wrench on it to see the torque on it
    '14 JK Sport Anvil 6-Spd 3.73 gearing
    Installed:
    -Rubicon Express 2.5" lift with monotube shocks
    - Cobra Cb 18 WX STII
    - 285/70/17 Duratracs
    - 1.5" G2 Wheel Spacers
    - Rigid Dually Spots
    - Poison Spyder A-Pillar Mounts
    -RC 2.5" swaybar disco's
    Awaiting Install:
  5. #5
    Join Date
    May 2014
    Location
    Ontario
    Posts
    761
    Update no more squeak cranked em down some more cycled the suspension and is now gone. New question though can you/is it safe to press out the sleeve in the stock link and run the quick disco pins? Is it even possible to press out the factory sleeves lol
    Installed:
    Awaiting Install:
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
