Torque on bolts from rear driveshat to axle
JRied
I believe there is no torque spec for those bolts. Tighten them till there snug and use loctite. I may be wrong so wait for another reply
I just went and and looked back at a thread I made for replacing my rear pinion seal to see if I could locate that torque for you. No suck luck.
I got a copy of the dealerships repair procedure from Computeruser6, and it did not mention that torque either. However, you could ask him if there is one for those bolts. He may be able to get it if it exists.
I just tightened till I was satisfied. No issues to this day so it must be tight enough.
Finn Sizzle
Thanks for the feedback all, appreciate it. I could not find it scouring the interest either.....yep, loctite and tightened up. I marked them and I'll check to see if they loosen, don't think they will.
Thanks again!
