Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Build planning questions.
  1. #1
    Been Around the Block Scoop315's Avatar
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    446
    To start a build on the TJ X 6 speed manual I have, and on a small budget to start with, where should I start, after recovery and safety upgrades? I want to get my hands dirty on as many of these projects as I can.
    Here is my intent for the rig. Generally, I'm shooting for American made products that will stand up to harder punishment than I'll throw at them.
    33"-35" tires on bead lock wheels
    A strong and safe steering system
    A suspension system that can take a beating
    A safe lift to body and suspension
    Dynatrac Pro Rock 44s front and back, ARB air lockers, 4.88 gearing
    The ability to do MOAB reasonably well, even though the TJ wheel base is short, but also able to take on East Coast conditions of rain, mud, snow, river crossings, rock crawling, etc.
    Still maintaining daily driver status
    Is my best bet on suspension and steering first? Or axle upgrades? And of course, I realize that lifts mean changing out drive shafts. I'm thinking tires and wheels can come later.
  2. #2
    Token East Coast Guy MR.Ty's Avatar
    Join Date
    Apr 2014
    Location
    South East Georgia
    Posts
    6,547
    I moved your thread to the TJ/YJ tech section.
    What rear axle do you have? Are you sure that you only want 35s?
    And Dynatrac does not make a PR44 rear. They offer their trail series for the TJ.
  3. #3
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    446
    Quote Originally Posted by MR.Ty View Post
    Anything larger than 35's would be excessive, I'm thinking.
    Thanks for the correction on the pr44.
    I believe I have a D35 rear. The X is completely stock, as near as I can tell.
  4. #4
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    446
    This is why I come to the forum... Mr Ty has already helped by getting me to look at what is actually offered.
    living in Pennsylvania, to pass the state vehicle inspection standards, wheels can't be past the wheel flares of the vehicle. There would of course be the option of buying a wider flare to accommodate larger tires and spacers on the wheels to a certain degree. But, I don't want to make the stance too far out. I'm thinking (please correct me if I'm wrong) of keeping front and rear axles close to stock in width.
  5. #5
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    446
    This might be my answer, though I'm leery of electric lockers.
    http://www.dynatrac.com/axle-assembl...ssemblies.html
    The nice part is the stock suspension and steering is compatible. That allows me to get the axles out of the way until I have the $$ for lift, suspension, steering and driveshafts.
    Thanks Mr. Ty!
    Edit: should I opt for this, or look at a PR60 rear, with a PR 44 front? The reason why I'm asking is because of the ARB air lockers on the Pro Rock, which as I understand it, is far more reliable than electrically controlled lockers.
  6. #6
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    446
    The great thing about my build planning is that I still haven't shelled out any money yet.
    I'm leaning more towards a Trail Series 60 semi float rear.
    I'd love to go full bore with a 44/60 hybrid up front, but both axles together are going to cost $11-$12k.
    I need to get a 2nd job...
  7. #7
    Knows a Thing or Two holliewood61's Avatar
    Join Date
    Mar 2015
    Location
    Peterstown Wv
    Posts
    525
    You might want to check out the offerings from east coast gear supply. They will usually cut you a pretty good deal if you call and talk to them. When I put the dana 44's under my cj they hooked me up with 2 sets of yukon 4.88's, 2 install kits, and 2 aussie lockers for under a grand.
    To run 35's a ford 8.8 rear and a waggy 44 front would more than suffice, and could be thrown together on a budget
    Beat it to fit, paint it to match
    08 WK
    00 WJ
    99 TJ
    81 CJ7
    60 CJ5
    Best wheeling in WV
    http://trailsheaven.com/Plan-Your-TR...vy-Branch.aspx
  8. #8
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    446
    Quote Originally Posted by holliewood61 View Post
    Thanks. I'll look into it, to see if it can take trail punishment and still work.
  9. #9
    Join Date
    Mar 2015
    Location
    Peterstown Wv
    Posts
    525
    Ive set up several for tj's, the 8.8 is arguably stronger than a 44 if you use a c-clip eliminator. They would keep you close to factory width. The waggy 44 would give you lock out hubs up front and the 8.8 could give you disc brakes in the rear if you keep your eyes open for a disc brake unit. Im not sure what gear ratio you're eyeballing but some could be had with 4.10's.
    08 WK
    00 WJ
    99 TJ
    81 CJ7
    60 CJ5
    Best wheeling in WV
  10. #10
    Join Date
    Mar 2015
    Location
    Philadelphia
    Posts
    446
    Awesome! Thanks for the info.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
