2012 Dozer JKU - this might take a while
devonn216
I traded in my 2003 WJ because it needed a good amount of work and I desperately wanted back into a Wrangler! ImageUploadedByWAYALIFE1435147691.339239.jpg ImageUploadedByWAYALIFE1435147702.925601.jpg
I got a 2012 Dozer JKU Sport with 60k on it. It didn't have all the things I wanted, but I searched and searched for a Dozer and the price was right on this one, plus is was in great shape and had a Trektop. ImageUploadedByWAYALIFE1435147868.088532.jpg
2012 JEEP WRANGLER UNLIMITED X 4X4 SPORT UTILITY 4-DOOR
*A7 Cloth Seats w/Adj. Head Restraints
-X9 Black
AAJ Connectivity Group
AHT Trailer Tow Group
AJPP Power Convenience Group
APAS Monotone Paint
BABS 160 Amp Alternator
BC2S 600 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BNGS Hill Start Assist
BNHP Hill Descent Control
BNMP Traction Control
BNSP Electronic Roll Mitigation
BNTP Trailer Sway Damping
BPTP Hydraulic Assist Brake Booster
BRWS 4-Wheel Disc Brakes
CACS Low Back Bucket Seats
CDBS Reclining Front Seats
CDHP Driver Height Adjuster Seat
CFNS Rear 60/40 Folding Seat
CGXS RR Head Restraints Outboard Seating
CG3S Advanced Multistage Front Air Bags
CKES Front Seat Area Carpet
CKFP Rear Seat/Wheelhouse/Cargo Carpet
CKLS Cargo Compartment Floor Mat
CKTS Cargo Tie Down Loops
CLES Front & Rear Floor Mats
CLMS Sport Bar w/Full Padding
CSMP Front Seat Back Map Pockets
CUFS Full Length Floor Console
CURS Rear Compartment Covered Storage
CUYS Storage Tray
CVCP Chrome/Leather Wrapped Shift Knob
DBAC All Automatic Transmissions
DGJ 5-Speed Auto W5A580 Transmission
DHES Command-Trac Shift-on-the-Fly 4WD
DJRS Next Gen. Dana 30 Solid Front Axle
DMCS 3.21 Rear Axle Ratio
DRZS Next Gen. Dana 44 HD Rear Axle
DS7S Conventional Differential Frt Axle
DS8S Conventional Differential Rear Axle
ERB 3.6L V6 24V VVT Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GCDP Deep Tint Sunscreen Windows
GCFS Full Metal Doors w/Roll-up Windows
GNAS Rear View Day/Night Mirror
GNUS Sliding Sun Visors w/Mirrors
GTBP Power Heated Mirrors
GWKP Sunrider Soft Top
GXMP Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
JA2S Premium Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JFJS Temperature & Compass Gauge
JHAS Var Intermittent Windshield Wipers
JJFS Single Low Note Horn
JJJS 12V Auxiliary Power Outlet
JKAS Glove Box
JPBP Power Locks
JPYP Pwr Windows, Front 1-Touch Down
LABS Tire Pressure Monitoring Warning LP
LAXS Front Passenger Seat Belt Alert
LAZP Vehicle Information Center
LCLS Front Dome w/On/Off Switch Lamp
LHES Rear Dome w/On/Off Switch Lamp
LMAS Halogen Headlamps
LNJS Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MBAS Black Front Bumper
MB5S Black Rear Bumper
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MGXS Wrangler Unlimited Badge
MRK Tubular Side Steps
MT2S Trail Rated Badge
MUGS Accent Color Fender Flares
MVCS Jeep Badge
MVJS Sport Badge
MX4S Black Sunrider Soft Top
NAS 50 State Emissions
NF5S 22.5 Gallon Fuel Tank
NHAP Engine Oil Cooler
NHMS Speed Control
PY5 Dozer Clear Coat
QY5S Dozer Clear Coat
RCGS 8 Speakers
RDDS Fixed Long Mast Antenna
RDZS Steering Wheel Mounted Audio Ctrls
RESS Uconnect 130 AM/FM/CD/MP3
RSC SIRIUS Satellite Radio
RSPP Uconnect Voice Command w/Bluetooth
RSUP Audio Jack Input for Mobile Devices
RSXP Remote USB Port
SBAS Power Steering
SCVP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SHAS Front Stabilizer Bar
SHCS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBRS Outside Tire Carrier
TUFP P255/75R17 OWL On/Off Road Tires
TZAP Goodyear Brand Tires
WFFP 17X7.5 Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XBNP Tip Start
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XEWS 2 Front & 1 Rear Tow Hooks
XFNP Class II Receiver Hitch
XFUP Trailer Tow w/4-Pin Connector Wiring
XJFS Tethered Fuel Filler Cap
XJGS Non Locking Fuel Filler Cap
XLNS English/USA Language
XPFS Protective Coating and Remover
XSBS Midnight Star Interior Accents
X8ZS Seat Parts Module
X81S Instrument Panel Parts Module
X83S Front End Parts Module
X86S Complete Chassis Parts Module
X88S Tire & Wheel Parts Module
X9AP For More Info, Call 888-539-7474
X9BP 1-Yr. SiriusXM Radio Service
X92S Complete Body in White Parts Module
X94S Complete Painted Body Module
YAAS Build To U.S. Mkt. Specifications
Rubicat and olram30's Dozer build are my inspiration. I have a rough plan in my head about what I want to do, but I'm sure as things fall into place it will change numerous times. Eventually I'll have Prorocks, EVO double throw downs, 37s, and all that high dollar stuff that comes with it! Hopefully. We will see :/
devonn216
On to the additions!
My WJ had Weathertech mats that saved my ass numerous times so that was the first addition. (Starting the build thread a little late so they are worn-in and dirty) ImageUploadedByWAYALIFE1435149181.681449.jpg ImageUploadedByWAYALIFE1435149191.575665.jpg
Next to come was upgrading the horrific factory reverse lights so I can actually see when backing down my driveway at my mountain house. I followed a write up a found, but forgot to take pictures during the install. I used the Rigid Industries SR-Q Flush Mount Back Up Light Kit (SKU: 98003). It was pretty easy. Just remove your taillight housing by undoing the two inward screws. Disconnect the wiring. Use the gasket provide in the Rigid kit as a template for you cut. It lays perfectly over the clear backup light section. Cut the hole with a Dremel. Drill two hole for the mounting bolts provided, they tap nicely into the plastic taillight. There a bit of wiring to be done, PM me for details or find the write up. Plug everything back up. Reinstall the housing and boom. Took me about an hour, and now my reverse lights are brighter than my headlights! ImageUploadedByWAYALIFE1435149230.253234.jpg ImageUploadedByWAYALIFE1435149238.015748.jpg
Next was my WAYALIFE windshield decal! ImageUploadedByWAYALIFE1435149266.990737.jpg
And a little playing around in the construction site by my house. I haven't had a chance to do anything really exciting yet off-road wise. There's a little steep hill/mini cliff thing in the front of my mountain house I messed around on, but again forgot to take pics. Sorry. ImageUploadedByWAYALIFE1435149302.844013.jpg ImageUploadedByWAYALIFE1435149317.859649.jpg ImageUploadedByWAYALIFE1435149332.096702.jpg
I'm in love with the color!
I planed on buying an EVO Enforcer, all the things needed, wheels, and tires all at the same time, but that went quickly astray when I found a steal on a set of five 315/70/17 Mickey Thompson Deegan 38s on 17" XD Addicts. They weren't going to be my choice, but they look awesome and the price was right, so I jumped! Got them with only 800 miles on them for $1600 bucks. ImageUploadedByWAYALIFE1435149618.151538.jpg ImageUploadedByWAYALIFE1435149633.143323.jpg
I couldn't resist trying to stuff them on just to see what they would look like and how much rubbing and all it would give until i trim my fenders, chop my bumpers, and lift. ImageUploadedByWAYALIFE1435149691.553550.jpg ImageUploadedByWAYALIFE1435149705.255029.jpg ImageUploadedByWAYALIFE1435149713.301338.jpg
For daily driving they are fine! They rubbed just slightly while turned and reversing on the air dam under the front bumper so I trimmed the lower corners off of it and now there's no rubbing what so ever! I wouldn't dare take it off-road though! I jumped a curb to avoid traffic yesterday and was fine there too haha. I need a fender trim and lift ASAP though!
O yeah I removed the Jeep mud flaps when I put the tires on, and the chrome taillight guards when I did the reverse light install.
Also got some new WAYALIFE JK decals for the sides! :)
ImageUploadedByWAYALIFE1435149980.845974.jpg ImageUploadedByWAYALIFE1435149990.610179.jpg
I'm going to tackle the front fenders tonight hopefully.
devonn216
It really bugs me that the previous owner got wax all over the black fenders. It looks like crap, and they are fading. Im liking about rattle can bed lining them when i do the trim. Any thoughts?
hinrichs
I forget what its called, but there is something that will clean them up with some good scrubbing and have them looking like new.
HoosierWolf
What gearing are you running and how does it feel on hills with the 35"s?
Looks great. Looking forward to following your build thread :thumb:
devonn216
Try armor all.Looking good.
I tried that and it lasted for a day before going back to normal. I also tried Goo Gone and it was the same.
Unfortunately it has 3.21 gears. I have lost 4 mpgs. Its pretty flat here in Charlotte, NC so its been alright. I can certainly tell a difference in the RPMs, especially at 55+. The real test will be this weekend when I drive up the mountain to Boone, NC. It gets pretty steep going up there so ill let you know how it does. I would definitely like to regear though.
Thanks! :beer:
devonn216
Started my fender chop last night. I will post some pictures when I'm done. I also have a few things coming in the mail! We will see what they are when they get here :yup:
devonn216
Well I'm pretty much done with my fender chop. I just haven't decided how I want to cut the corners, so I still have to do that and then put the trim on. I'm very happy with them! It looks like I've got a lift and I don't! I tried very hard to keep as much of the mud guards as possible and it seems to have worked out nicely. You can't tell in the pictures but I did the passenger rear mud guard a little better than the driver side since I did if second. I followed a few different chop threads and then still kinda did my own thing. It's really all personal preference.
ImageUploadedByWAYALIFE1435322967.618717.jpg ImageUploadedByWAYALIFE1435322978.647017.jpg ImageUploadedByWAYALIFE1435322989.314393.jpg ImageUploadedByWAYALIFE1435323000.017494.jpg ImageUploadedByWAYALIFE1435323011.858383.jpg ImageUploadedByWAYALIFE1435323022.601067.jpg ImageUploadedByWAYALIFE1435323037.376510.jpg ImageUploadedByWAYALIFE1435323216.951060.jpg ImageUploadedByWAYALIFE1435323227.933915.jpg ImageUploadedByWAYALIFE1435323238.073789.jpg
I'll post some finished product pics when I get the corners and trim done.
Next will be the bumper chop!
devonn216
By the way I wanted to leave the black mud guard in the rear only because I wanted it to be black instead of Dozer in there, and because I was too lazy to paint it all.
olram30
Not That Kind of Engineer
Looks good! Dozer and black look good together. Might have to trim your pinch seams.
devonn216
Yeah im very happy with the colors! the pinch seams are on my list of things to do, but for now its alright on my daily commute. probably with do them over the July 4th weekend.
devonn216
Im also going to paint the flares and probably the bumpers too since they have faded so much. im thinking of trying a rattle can bedliner...not sure though. might do the steps too, but they are just on temporarily to make my GF happy, and unitl i get some sliders.
MR.Ty
Token East Coast Guy
Somewhere in Olram's build thread he used a cleaner to get them black again. I'd try that first before you paint.
Edit: Your JK is looking great.
devonn216
Thanks! :beer:
Yeah I saw that in his thread. I have tried a few different cleaners, and none of them lasted more than a couple days. I havent been able to find the exact cleaner he used locally. Might try and order some.
, how long did it last after you used the cleaner? If i recall your thread correctly it didnt last all that long.
olram30
Thanks! :beer:
Yeah I saw that in his thread. I have tried a few different cleaners, and none of them lasted more than a couple days. I havent been able to find the exact cleaner he used locally. Might try and order some. Olram, how long did it last after you used the cleaner? If i recall your thread correctly it didnt last all that long.
If yours were like mine, the little pores were full of old build up, I really think any cleaner or degreaser to get the old stuff out of the pores should work. I've been using wd40 lately. Works ok.
devonn216
Are yours faded greyish? How long does it last? I want something more permanent that im not going to have to redo weekly.
olram30
They were pretty bad. But upkeep is key unless you have a garage.
