Someone's always gotta be that one jackass and it looks like I gotta raise my hand on this one. Be aware if you do this you may bow your windshield frame some. I did this in order to get the gap tighter on my install and now air infiltrates my hardtop so bad it sounds like one of the windows are down. Keep this in mind if you're running a Freedom top. If you're running a soft top you shouldn't have any issues as that top doesn't have the seam in the middle.
Man, I tried silicone and black weatherstripping cement but it still leaked. I finally put black Gorilla Tape over the seams and that stopped it.Can't wait for soft top season though.
2014 JKUR
Build: http://wayalife.com/showthread.php?3...l-build-thread
I'm sure it does a bit. But I'll get some longer bolts to make sure I make use of all the available threads. Odds of rolling already not huge. Odds of rolling in such a way that the gap ends up making difference, even smaller.
Odds of me being annoyed every time I drive it with a whistling sound: high.
Much thanks for the insights DDays.
2014 JKUR
I would take out the bolts at the windshield then use the strap. There should be enough play to run them back in afterwards. If not then dremmel the holes a bit wider. A tight fit is crucial to the integrity of the cage IMO.
1999 Grand Cherokee: https://wayalife.com/showthread.php/...aid-a-WJ-story
Reluctantly sold:1979 CJ-5 - Project Old School https://wayalife.com/showthread.php/...ect-Old-School
Sold: My old JK build http://wayalife.com/showthread.php?4...the-Yellow-JKU
Sold: 2018 JL Sport S https://wayalife.com/showthread.php/...New-JL-Sport-S
2014 JKUR
Two bolts where the visor mounts, one bolt on the side that you can access through the plastic mounding
