Page 7 of 7 FirstFirst ... 567
Results 61 to 69 of 69
Thread: EVO Rock Star Installation Write-Up
  1. #61
    Hooked devwil68's Avatar
    Join Date
    Oct 2012
    Location
    Granbury, Texas
    Posts
    143
    I just Took delivery of some fusion 4 x 4 axles which are Dana 60 and order new rockstar skids. It looks as though the bracket tree works without the skids, should I have any concerns not using the Evo brackets?
    Rock Krawler 3.5" Mid-Flex | Pro-Comp Pro Runner Shocks | ATX Chamber Pros | 37" MT MTZs | Smitty MOD Front Bumper | Smitty 10k winch | Smitty Rear Bumper/Tire Carrier | Smitty Fender Flares | Teraflex Front/Rear Bump Stops | Dynatrac ProRock 44 Unlimited | ARB Locker | ARB onboard air | Rock Lights | G2 4.88 Gear | Dynatrac Rear Diff | EVO Front Coilovers | Currie Front AntiRock
  2. #62
    Addict BaddestCross's Avatar
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,639
    Quote Originally Posted by devwil68 View Post
    The purpose of the Rockstar skids is to get you better ground clearance. They aren't required if you don't have that concern.
    Build Thread: The Adventures of Fiona
    '08 JKR Rescue Green 2-Door
  3. #63
    Join Date
    Oct 2012
    Location
    Granbury, Texas
    Posts
    143
    Quote Originally Posted by BaddestCross View Post
    I was thinking they had some sort of geometry correction for the coilovers as well? Not true?
  4. #64
    Join Date
    Aug 2016
    Location
    Palmdale, CA
    Posts
    5,639
    I may be wrong but I'm unaware of that requirement. I installed them on my JK with regular shocks and it just moves the mount 1.5" higher, no change in angle.
  5. #65
    Nothing but a Thing desertrunner's Avatar
    Join Date
    Mar 2013
    Location
    Great Falls, MT
    Posts
    2,131
    The geometry of the bracket looks a little different but I think its because the mounting holes are more in the back instead of off to the side also by moving the bracket up puts the shock at a slightly different angle. But as far as I know its unrelated to the coil overs
    12' 2dr Gecko Sport 6 speed
    PR44, ARBs, 4.88s, 35 spline rear, Adams 1350 Front & Rear, Rubi T-case, Rubi sway bar + Evo no limits, Evo armor & skids, 37/13.50" Cooper STT Pro, Evo 2" plush / OME med duty springs
    ***SOLD*** 08' JKU Rubicon 6-speed Stone White, 3.5" RK lift, 37" KM2s and lots more.
    ***CURRENT DD*** 16' F150
  6. #66
    Old Timer DWiggles's Avatar
    Join Date
    Jul 2014
    Location
    Texas
    Posts
    3,714
    Quote Originally Posted by desertrunner View Post
    Sway bar link should be on the inside of the rockstar...
    sent from SPACE!
    DZZ Build thread
  7. #67
    Nothing but a Thing jdofmemi's Avatar
    Join Date
    Mar 2018
    Location
    Menifee CA
    Posts
    2,157
    The lower shock bolt should be turned around. If you wheel much with the net and threads inside, they will be near impossible to get off later on.
    Plus the bolt head don't stick out as far to grab like an anchor.
  8. #68
    Join Date
    Mar 2013
    Location
    Great Falls, MT
    Posts
    2,131
    Thanks for the input guys appreciate the concern. I have since changed out to evo swaybar links and swapped that bolt after that picture was taken
  9. #69
    Join Date
    Jul 2014
    Location
    Texas
    Posts
    3,714
    Glad you got it figured out
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
