Originally Posted by
Well, I may have accidentally fixed this cooling system problem today. I pulled it in to diagnose it once again. Being that the problem seems to only occur with the ac on, I've been leaving it on when I diagnose it. Well today, when I started it, the ac clutch was binding and chattering and wouldn't engage. The belt even made an abnormal noise. I've also noticed lately anyways that the clutch cycles about every 5-10 seconds but has been making a slight rattle when it engages. It hasn't bothered me because the ac cools. So, I shut off the engine and removed the belt to make sure the compressor isn't locked up which it's not. Pulley spins fine as well. Well in the process of turning the hub nut, I must have adjusted something inadvertently, because now the clutch engages and hardly cycles at all, it stays running quite a bit longer, and the ac cools a ton better. But more importantly, the temps aren't rising anymore. I need to test it on a trail, but two long road tests today and it was fine.
Got to thinking, if the ac clutch wasn't fully engaging and I didn't know it, at idle this would definitely affect the water pump rpm, and this would also affect the refrigerant flow through the condenser. So I'm really hoping this is the end of this stupid problem.
