2015 SEMA Steer Smarts YETI Jeep JK Wrangler Steering Components
While this wasn't installed on a Jeep JK Wrangler at the 2015 SEMA Show, this YETI steering system made by Steer Smarts was on display and from what I am told, it's the strongest you can get for a JK. What I do like about it is that you are supposed to be able to install the drag link without having to drill out your knuckle and the tie-rod can be adjusted much like you can a factory unit.
jeeeep
I like the idea of not having to drill out the knuckles, reverse taper mount :thumb:
synergy parts coming up for sale soon :doh:
CJW
If you don't drill out the knuckle wouldn't you end up with a skinny shaft on the ball joint? At least on top of the knuckle where the drag link makes contact?
