Evo manual sway bar disconnect
Angry Aussie
Hey guys, I just installed the evo manual sway bar disconnect and now my sway bar light is flashing. Is there a way to turn it off? What have you guys done about this? Or am I the only one it's happened to.
j3rs3yd3vil
I've heard the aev pro cal remedies that problem, I'm not quite sure otherwise though, you may be able to take it to the dealership and have them disable the light.
hyvltge
Is the nut a locknut to keep the handle on or are you supposed to tighten it down to the plate to make sure your sway bar stays connected during regular use?
JAGS
The latter and it just needs to be snug
Good to know. This may be my only solution as it appears my problem is not the motor. I may try one more motor swap...not holding my breathe.
Possibly a bad harness, bad switch or bad mechanism.
piginajeep
The Original Smartass
You can wire it direct to a switch. Not a straight forward job but it can be done. If you are going with the knob, can I have the motor ??
More than likely it's the board
