Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 161
Thread: 01WJ build
  1. #1
    Hooked ty Mitchell's Avatar
    Join Date
    Oct 2015
    Location
    Cobleskill, new york
    Posts
    159
    01WJ build
    So almost 2 months ago I bought my wj. So far I've added lights, tints, cb, a lil paint and a fat bobs 2.5" lift. I'm currently waiting for an led cb antenna from Adams off-road and the hidden winch mount from hk offroad which should b here in the next couple wks. I'll add pics of the install process. I'm about to order some tires 285/70/17 and was wondering if I can fit these without cutting yet?
    Attached Images Attached Images
  2. #2
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,696
    Quote Originally Posted by ty Mitchell View Post
    285/70R17 are about 32.7ish in diameter. I run 255/75R17 JK tires (32.0 diamater). With my 4 inch lift I had to trim a fair amount. If you aren't afraid of trimming, I'd say go for it and get the tires and adjust accordingly. You will most likely need wheel spacers and/or wheels with proper backspacing to make sure they clear. Also, with that big of a tire, you will most likely have to relocate your washer bottle under the hood instead of inside the LF wheel well. You can buy a 98 ZJ washer bottle all day long for cheap and it has all the necessary holes to convert your WJ pumps and level sensor into the new bottle. Then re-locate it under the hood.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  3. #3
    Join Date
    Oct 2015
    Location
    Posts
    159
    OK thanks . I guess I'll order the tires then get the flares next month and make it one big project for a weekend. I purchased a tuff stuff 9500 winch with 85ft of cable. Eventually I'll swap it out for a synthetic rope
  4. #4
    Join Date
    Oct 2015
    Location
    Posts
    159
    Hidden winch mount soon to start
  5. #5
    Join Date
    Oct 2015
    Location
    Posts
    159
    Removed solenoid guts for better placement behind bumper
  6. #6
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,696
    Anxious to see the finished product.
  7. #7
    Nothing but a Thing boardsurfer's Avatar
    Join Date
    Jan 2015
    Location
    5280
    Posts
    1,718
    The hidden winch looks cool!
  8. #8
    Join Date
    Oct 2015
    Location
    Posts
    159
    Started getting dark. Will continue in the morning. #Ineedagarage lol
  9. #9
    Join Date
    Oct 2015
    Location
    Posts
    159
    Thanks y'all I'll continue posting pics thru the process
  10. #10
    Join Date
    Oct 2015
    Location
    Posts
    159
    Can't wait till its done
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
