Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 41
Thread: The ISSUES with 16" Wheels on a Jeep Renegade Trailhawk
  1. #31
    Fresh Catch Alandude58's Avatar
    Join Date
    May 2016
    Location
    Plantation Florida
    Posts
    18
    Now that you have been running your 1 1/4" spacers for a while now, have you had any issues with them?
  2. #32
    Fresh Catch
    Join Date
    Oct 2016
    Location
    Texas
    Posts
    6
    Has anybody has any luck finding other 16" wheels that fit over the TH massive brake calipers?
  3. #33
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    45,352
    Quote Originally Posted by ElZorrodelSol View Post
    No. The only way I could find to clear them was to run 1.25" wheel spacers and that was with a thinner steel wheel. Aluminum wheels are going to be a lot harder to make work.
  4. #34
    Fresh Catch
    Join Date
    Oct 2016
    Location
    Texas
    Posts
    6
    Have you had any issues with the thinner HHR wheel? I imagine not much of an issue with the taller side walls, but just don't want to go bending a rim. Is air down an issue?
  5. #35
    Fresh Catch
    Join Date
    Oct 2016
    Location
    Texas
    Posts
    6
    Sorry, another question. Would it be possible to get a new 16" wheel with an offset of say zero? This would push the wheel out the 41mm from the stock TH wheel. This would be about 3/8" further out than the 1.25" spacers. Would back spacing then be a problem?
  6. #36
    Fresh Catch
    Join Date
    Dec 2016
    Location
    Arizona
    Posts
    9
    renegade lift
    i just bought a 2016 renegade trailhawk. its good to know about the fitment issues, with 16 in wheels. the parts guy at the local jeep dealer in Tucson said the calipers and rotors where the same on all renegade 4x4s.
    makes me wonder if its worth lifting it or not. im not a big fan of spacers.
  7. #37
    Fresh Catch
    Join Date
    Apr 2016
    Location
    The Blast Furnace
    Posts
    30
    Quote Originally Posted by Mowry67 View Post
    I'm basically intending on doing rocker panel protection before I do anything else that requires serious work. I used to take my folks '99 Tracker out and the only thing I ever did to it was to come down on a rock and put a crease on a rocker. Fortunately not too severely, but enough that if you know where to look you can see it.
    Kicking the wheels out a bit also appeals and is very easy compared to so many other things, but I'd rather find wheels manufactured with the right offset if possible. This is the first 4x4 with this bolt pattern so I'm not exactly surprised that we haven't seen aftermarket wheels like this yet.
  8. #38
    Fresh Catch
    Join Date
    Dec 2016
    Location
    Arizona
    Posts
    9
    Quote Originally Posted by TWX View Post
    Yes that's exactly what in finding out. I'm thinking of some steel wheels till the choice improves
  9. #39
    Fresh Catch
    Join Date
    Dec 2016
    Location
    Arizona
    Posts
    9
    That's what im hearing .. but local jeep dealer told the calipers are the same on all renegades. Yet the renegade sport comes with 16in wheels. So its like WTF, or is it the rotars the are bigger.
  10. #40
    Fresh Catch
    Join Date
    Dec 2016
    Location
    Arizona
    Posts
    9
    Being that I don't have a Latitude, I can't say for sure. What I know is that for 2015, the Trailhawk was supposed to come with front rotors that were about an inch wider in diameter than a Sport, Latitude or Limited. This was supposed to change in 2016 and ALL Renegades are to come with the same brakes.
    That being said, are you running 16" wheels now? If so, I would think you'd be fine. If not, measure your front rotors and if they're 11" in diameter, you will be fine. If they measure 12", you will have the same brakes that we have on our Trailhawk and you will need to run spacers to make the HHR wheels work.
    Good to know .ive got a 2016. I'll be lifting in the next couple of months..love the look of the cooper stt pro
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
