Direct Fit LED Fog Lights for JK's - OEM Replacements to Match Truck-Lite headlights
TJeep_1999
I’m replacing my stock headlights for the new truck-lites. I was thinking that I would also replace the factory fog lights at the same time. I’ve found a ton of posts on the headlights, but not a lot about the fogs. One thing I quickly realized was that the fogs cost almost as much as the headlights! I’m hoping someone here can help me with the below questions:
1. Anyone have luck changing out just the bulbs to better match the LED headlights?
2. Do I have to worry about the flicker issue with the fogs? If so does anyone make an adaptor?
3. Any recommendations on fog light brands/models that would fit into the stock bumper holes/mounts?
Thank you in advance!
Jern26
Quadratec makes some led replacement fogs. I think they come with anti flicker pigtails but not 100% sure. But they're $180 a pair
RockyJk
I got some from LEDs4less they are JW knockoffs but work good and are pretty bright, should work on stock bumpers
JeepJeep75
I have Trucklites also and wanted my dogs to match. I replaced just the bulbs with LED's from JDM ASTAR as well. Color temp is a perfect match. However, the fogs do flicker on my '15. It's not noticeable at all until the lights are hitting my garage door. The LED fogs look really, really nice. But as far as performance, they just spray light everywhere, which is perfect for my mall-crawling needs. [emoji51][emoji51][emoji111]️[emoji112]
hlax2525
I just picked up a kit from inspired engineering for factory fog light replacements as LEDS. They came with a factory plug and play harness and from what Ive seen they are really bright. Also come from an american company, and have a great price point at just over $200.
jeeeep
I did the same thing, $20+ well spent
what LED's did you order form where? I tried the same thing and the LED's I bought did not fit the plug or the fog lamps properly even though they were supposedly made as a replacement.
jorgelrod
Which one did you get? The CUBE kit with OEM replacement fog light mounts? how are they working for you?
mds22
Amazon, I'll get the actual part number/link. I have it written down somewhere
Renzo1200
Quadratec plug and play FTW. Bulb replacements never fit correctly or will burn out in a year. Skip the knock offs as well, not worth the short term savings.
wackamole
The flicker is just something we have to deal with on the newer electrical systems.. I put in truck-lite headlights and then installed the Baja Designs Squadron pros as fog lights.. You're going to need an anti-flicker module. When I get home, I'm going to move my BD's to my A pillars and install JW Speaker 6145 J's for fogs. They have a built in anti-flicker module, so you shouldn't have to worry. But they also come with the JW price.. roughly 360USD from Quadratec.
http://www.quadratec.com/products/97009_814X_PG.htm
phi502
I have these same bulbs in my fog lights. I have been pretty pleased with them for the price. They definetly have a more white to slightly bluish color to them. They also seem to be a quite a bit brighter than stock.
If you go this route, I would put a little bit of lubricant on the o-ring. They fit very tight in the housing. I was unable to get them to snap in fully. I had some multi-purpose marine lubricant in the garage. I put some on there and they snapped in much easier.
phi502
Not the best picture, but it gives you an idea vs. the stock headlight.
