Results 1 to 9 of 9
Thread: Steering stabilizer with PR44 and Synergy Steering
  1. #1
    Fresh Catch troy-bilt's Avatar
    Join Date
    Sep 2014
    Location
    Omaha, NE United States
    Posts
    24
    Just got done installing my PR44 and Synergy Tie rod/drag link. What is everyone running for a steering stabilizer with this setup. Drives perfectly with out one but figure can't hurt to have one to save a little wear and tear.
    P.S. Factory is long gone and the Rancho I had was blown at some point so nothing from old setup to move over to new.
  2. #2
    Knows a Thing or Two tgoss's Avatar
    Join Date
    Jan 2016
    Location
    San Diego
    Posts
    808
    Quote Originally Posted by troy-bilt View Post
    I have the exact same axle and tie rod / drag link getting installed today. I'll be running the Fox ATS until I can financially swing a hydro set up. Will definitely update later this week if you're interested in how it works out.
  3. #3
    Been Around the Block Buster3479's Avatar
    Join Date
    Mar 2014
    Location
    Lexington Park, MD
    Posts
    462
    Find a takeoff stocker from someone who was led to believe they needed to "upgrade". It will function the same or better depending on what aftermarket one you end up with. I had a Fox ATS and liked it, but not worth the cost.
    2012 Deep Cherry Red Freedom JKU "Beast", 5.13 Auto, 4:1 Xfer Case, ARB front/rear lockers, Dynatrac Prorock 60 Fr / Pro 60 Re, 40x13.5R17 Nitto Trail Grapplers, Raceline 8x6.5 Beadlocks, 4" Evo Plush Ride Springs, Billstein 5160 shocks, Switchpros, EVO Fascia & AEV Tire Carrier, EVO 1/4 lber / Stinger, Warn 9.5 CTI, EVO Air No Limits on Demand & Links, EVO Sliders, EVO Protek Skid System, EVO Rockstars, Heated Truck-lites, JW Speaker Fogs
  4. #4
    Join Date
    Sep 2014
    Location
    Posts
    24
    Will the brackets work with the larger tie rod?
  5. #5
    Guy with a Red 2-Door cozdude's Avatar
    Join Date
    Mar 2013
    Location
    West Chester, PA
    Posts
    18,751
    You can find a factory take off on Craigslist for pretty damn cheap
    October 16, 2013, wednesday early evening, east of the pacific ocean, selectee for truly random and boring Parking lot photo of the moment grand platinum prize winner!
    2011 JK
    EVO Bolt-on Coilovers, EVO 1/4 pounder w/ stinger, 37" Cooper STT Pros, PR44, and some EVO stuff
    Awaiting install-
    On Order-
    Want list- Evo carrier and skins, PSC hydro assis
    jlwrangler.com
  6. #6
    Addict hinrichs's Avatar
    Join Date
    Nov 2012
    Location
    Wyomissing, PA
    Posts
    5,658
    I vote factory untill you can upgrade to hydro assist. I ran a stock one on both my jks on 37s and it was more than enough.
  7. #7
    Join Date
    Mar 2014
    Location
    Lexington Park, MD
    Posts
    462
    Sorry, I don't actually remember. I ran a Synergy Tie rod with both the Fox ATS, and later a stock stabilizer at one point in time. There are also two stock brackets, one with U-bolts, one with a bent metal clamp, I think the U-bolt one fits on a wider variety of tie rods. There are also several aftermarket clamps I've owned, including one by Synergy, but the bolt that fit in that might not make it through the newer stock SS, the older one had a different I.D. bushing.
    In the long run, I've ditched everything Synergy off my rig, arms, TB, DL, TR, and replaced most of it for what I believe is better and stronger stock or other stuff. Sounds counter-intuitive to some, especially on other forums. If I can find a picture of what bracket I used when I had a stock one on with a Synergy TR, I'll let you know.
  8. #8
    Been Around the Block Sullivan's Avatar
    Join Date
    Sep 2014
    Location
    Chicago's South Side Irish
    Posts
    360
    Fox steering stabilizer here. Same set up with PR44 and synergy steering components up front. Works good.
    I'd say get the larger stabilizer. Why are we pinching pennies here when we purchased a Prorock? ImageUploadedByWAYALIFE1454359399.918974.jpg
  9. #9
    Join Date
    Sep 2013
    Location
    Long Island
    Posts
    204
    Quote Originally Posted by tgoss View Post
    Spending that much on a stabilizer is crazy especially if you want hydro assist. You can get the redneck ram hydro assist system for not much more than the fox ats. This system has been working flawlessly for me
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
