Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
Thread: Harbor Freight 440lb Electric Hoist - Leaving Hardtop up
  1. #51
    Knows a Thing or Two Jk909's Avatar
    Join Date
    Sep 2014
    Location
    Rancho Cucamonga
    Posts
    688
    Anybody try a couple snatch blocks with their winch to lift it? After its up it could be secured with some tie downs
  2. #52
    Nothing but a Thing sipafz's Avatar
    Join Date
    Mar 2015
    Location
    Saukville, Wisconsin
    Posts
    1,188
    Quote Originally Posted by japatton View Post
    Nice!! I forgot to mention that I used heavy duty lag bolts instead of the bolts included with the kit. You had a lot of little issues that I didn't. Strange, I wonder if I got lucky for once!! in going to change out the eye bolts with a shorter set to gain a little more height, I think. Or, cut the included eye bolts and rethread them.
    Thanks! Others had mentioned that the hardware was low quality so I was't surprised when a few of the heads twisted off. I probably should have predrilled the holes. The other issues had to do with truss clearance that could have been avoided with a bit more layout and dry fit. In the end it works well and I feel that the top is safe and secure! Now, if we could get some nice days I would like to use it! Thanks again for the pictures and tips!
    Chris
  3. #53
    Caught the Bug japatton's Avatar
    Join Date
    Mar 2015
    Location
    Brandon, SD
    Posts
    55
    Quote Originally Posted by sipafz View Post
    Fancy? That's not fancy! Fancy would be to combine the Racor lift and electric hoist! Also considering!
    If you figure this out, let me know!!
  4. #54
    Join Date
    Mar 2015
    Location
    Posts
    1,188
    I bought a soft top so the infrequency of using the lift does not justify putting anymore into it.
  5. #55
    Join Date
    Mar 2015
    Location
    Brandon, SD
    Posts
    55
    Same hear, I still might try to add a winch someday...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
