After a few glasses of wine and some dinner, I found myself starring at my clearance issue, pathetic right? What I noticed was that the gearbox could be mounted inside the bracket instead of outside as the instructions "suggest". [emoji6] time to sleep on it!
This morning I checked a couple of things to make sure my new plan would work and finished mounting the second rail. As others have mentioned the hardware that comes with this kit is not the best! I twisted the heads off of a couple of the lag screws.
I then mounted the gearbox on the inside of the bracket and test fit the winding bar and lock.
To get the gearbox mounted I had to file 1/16" from the bracket stiffener so the holes would line up. It's probably like that to keep you from mounting the gearbox on the wrong side. [emoji51]
Then I had to alter the lock bracket, spring ball set screw and spring, because the assembly would catch on the winder driver and preventing locking. I simply filed down the bracket and screw then cut 25% of the spring away. Now it all works!
Time to attach the platform, level & test.
With the kids Liberty in its normal spot.
With the top hanging I have a little more than 6' so for me I can walk under without worrying about bumping my head. All in, I have $180 invested and would do it again! Now if it would just stop raining! [emoji20]
