Page 30 of 34 FirstFirst ... 202829303132 ... LastLast
Results 291 to 300 of 333
Thread: Oscar's No Build Thread
  1. #291
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,677
    Quote Originally Posted by sipafz View Post
    Installed the backup camera. It was pretty straight forward with the hardest part being routing the camera wires with RCA plugs through the small holes drilled through the bumper.
    That came out great. Nice work.
  2. #292
    Fresh Catch
    Mar 2019
    NJ
    1
    Here’s the camera and harness:
    Attachment 322835
    I wasn’t sure if I needed this coupler, but of course I did. Picked up a pair at Walmart:
    Attachment 322836
    I started with plugging the harness into the back of the radio.
    I followed the instructions in this link to take part of the dash apart and get access to the back of the radio:
    https://wayalife.com/showpost.php?p=678054
    I also got some good info from this link for doing the wiring and mounting the camera:
    https://wayalife.com/showpost.php?p=453431
    Next I wired in the power connector to the passenger side reverse light. A white wire with gray stripe is the power. Use a 12volt test light to confirm and don’t forget to have the key in the run position, trans in reverse with parking brake set. Test again with the trans in park and you shouldn’t have any power. I snipped, stripped and spliced in the camera power wire:
    Attachment 322837
    Attach the ground to the tailgate hinge bracket, connect the video cable and make sure everything works.
    Drill the camera mounting hole through the plastic bumper cover using the hole saw supplied with the camera. The plastic cover is hollow in the middle so I used a 1/2” drill to make a hole through the second part and wallowed out the hole to make a slot. It was difficult to get the camera wires with RCA plugs through the bumper holes and a pry-bar was needed to get the wires over the metal part of the bumper.
    After that struggle, I cut a small slit into the rubber drain plug and routed the power plug to the camera plug, connected and wrapped with electrical tape:
    Attachment 322838
    Attachment 322839
    The video cable took the same route and continued up the passenger side floor, into the dash, up over the glove box an coupled to the radio harness. Add some electrical tape to secure the connections, tuck the remaining wire and your good to go.
    Daytime:
    Attachment 322840
    Attachment 322841
    Attachment 322842
    Attachment 322843
    Nighttime:
    Attachment 322844
    Attachment 322845
    The LED lights really do a nice job brightening the area.
    Total cost for this project was $42 and took about 4hrs to complete. The wife’s KK is next.
    Do you have a parts list or link to the harness you used?
  3. #293
    Old Timer sipafz's Avatar
    Mar 2015
    Saukville, Wisconsin
    2,565
    Quote Originally Posted by Stewnate View Post
    Harness:
    PAC CHYRVD Rear Video Retention Cable For Select Chrysler/Dodge/Jeep Vehicles 2008-2012 https://www.amazon.com/dp/B0051XBNDY..._3GsNCbCWTPRWC
    Camera:
    Rearview Camera Vehicle Backup... https://www.amazon.com/dp/B0792M37V5...p_mob_ap_share
  4. #294
    Mar 2015
    2,565
    First day of 60 degree weather so I decided to play hooky and left work after a half day. Oscar got a good cleaning and shed the winter gear for the afternoon:
    My lift sure makes it easy to ditch the top for a few hours:
    Unfortunately the chance or snow returns on Wednesday, 90% chance of 1” to 3” with a high of 37 degrees.
  5. #295
    Old Timer Jsouder53's Avatar
    Aug 2017
    Gallatin Gateway, Montana
    3,830
    Congrats on getting the hard top off! It’s a great feeling we have that same forecast. Image1554769058.306170.jpg it was nice for a few days after putting the soft top on, then got rainy lol
  6. #296
    Mar 2015
    2,565
    Quote Originally Posted by Jsouder53 View Post
    So this is happening:
    It was almost 70 degrees yesterday
  7. #297
    Aug 2017
    3,830
    Dang!! It was snowing today but not sticking
  8. #298
    Addict wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    6,000
    Yeah, it looks the same here in Detroit. Winters last breathe before summer gets here. At least you had a day with out the top!
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  9. #299
    Aug 2017
    3,830
    Image1555014393.684988.jpg this was this morning, after I said it wasn’t sticking
  10. #300
    Mar 2015
    2,565
    Spring break and Arizona can’t come fast enough.
