JCR skidplate to driveline clearance issue
Speedy_RCW
Flexed out the jeep today for the first time. Found this issue basically off the bat. When the front passenger tire starts coming up my front driveline makes contact with the skidplate right at the pinion flange. Looks like it was also contacting prior to the suspension install as well. I wasn't pleased with the way the skidplate fit to begin with and now even less pleased. I know my axle is centered and you really can't install the skidplate wrong so I dunno what's up. Any ideas or has anyone had this issue as well? I'm going to call JCR on Monday to see if it's something they're aware of and see if they can offer a remedy.
Here it is making contact
This is the clearance sitting of flat ground
Sorry for the shitty pictures.
GraniteCrystal
Can you take a zoomed out pic too? I have a JCR Crusader mid-width and may be able to show you what mine looks like. Which bunper/skid are you running? Right now just trying to figure out your pictures...
Let us know what JCR says too.
Speedy_RCW
This isn't related to the bumper. I'm still running the factory hard rock bumper. This is a transmission/oil pan skid for a manual tranny. Mounts from the transfer case crossmember to brackets that drop down from the motor mounts. Hard to get good pictures without a lift but here's a couple other shitty ones.
TFD
I've got about 2 inches of clearance on mine.
That being said, I had a hell of a time getting the drivers side bracket to line up. I called jcr and they gave me the run around. They wanted pictures and didn't seem interested. I ended up having to take it to my friends shop and do some cutting and welding to get it to fit.
Speedy_RCW
Thanks for the reply. Mine fit like shit but everything did line up. Don't have two inches clearance though. Drain plug didn't line up with the cutout so I ended up cutting the hole out larger and putting an access plate on. Shouldn't have to cut and weld on these things to make them fit right. I did some google searching and found some info. Read a couple people had the same sort of issue and got some kind of redesigned bracket from JCR. So we'll see what they say tomorrow. I'll keep you posted.
TFD
That's crazy that the drain hole didn't line up either. It looks like we made the wrong choice on engine skids [emoji19]
AllAmericanInfidel
So, JCR is on my short list for bumpers for my current project. I really do like the looks of their Mauler Deluxe front bumper and Mauler stubby rear bumper, but the more I hear stuff like this the most I become hesitant to even consider them.
GraniteCrystal
I have the Crusader bumper and skid plate and both went on without issue. You can see pics and write up in build thread if interested. There was a small issue with existing fogs, just a little tight, but no cutting welding needed.
Speedy_RCW
I don't have any experience with other JCR products so I couldn't say either way. But I definitely would not recommend their skid plates.
OJK12
I've had the opportunity to see a few of their products up close (TJ steering box skid, TJ front bumper, and the TJ inner fenders) they all fit like shit and needed modifications to go on. The hoop on the front bumper wasn't even the same on both sides one side had more of a bend than the other. Bunch of junk as far as I'm concerned, I'd have been pissed if I spent my money on that stuff to have it look like that and fit like that.
Speedy_RCW
Good to know. Thanks for the feedback.
As some of you may know, I think the guys at JCR are full of themselves and wouldn't buy any of their products just for that alone. That being said, I too have seen their products up close and in person and I too haven't been impressed with the quality of any of it.
Speedy_RCW
Yea I feel like I'm going to end up just having to ditch this skid or modify it. Called this morning and left a message with tech support. Traveling today so I'll call again when I get to the airport.
Being that you already have it and have it installed, I would just modify it and make it work. Sucks that you'd have to do that after spending so much money on it but, we've all been there. Well, most of us have anyway.
Speedy_RCW
Yea, my thoughts exactly. I mean a little fitting is no big deal but this is ridiculous. Here's a shot of how the drain plug lined up with the hole in the skid plate. Snapped this in the process of modifying the skid so I could actually change the oil without making a mess.
LOL!! Wow, that's some funny shit right there. :crazyeyes:
Sucks you have to deal with that. But I think you're making the right move by just modifying what you've got.
Jmjnewbold
:thinking: I dont see how that drain plug hole could be correct. :naw: I have been thinking about getting one of their bumpers for my project as well, but second guessing them more and more. :naw:
Sharkey
Word Ninja
Use a plumb bob to figure out the perfect angle hill to park on when changing your oil, then the oil will shoot right out of the hole. :crazy eyes:
Seriously, that sucks and I agree you shouldn't have to make major modifications to get something to fit right.
