Close
Results 1 to 7 of 7
  1. #1
    Old Timer USMC Wrangler's Avatar
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    2,822
    Help with my home brew bumper?
    I'm building my own front bumper and have a couple fab questions. I'm using 1/4" steel and it's already pretty heavy now. I'm wondering what to do on the back/inside? I've made it so when I can afford a winch it will be recessed. Should I "box in" and/or gusset it anywhere in particular? Here are a couple shots of where I stand with it now...
    I'd like to get it wrapped up and ready for paint this week. Thanks in advance!
    2013 JKU Sport "Spider" with some EVO goodies and a chop here and there
    DIY trail/tube door build http://wayalife.com/showthread.php?24449-My-DIY-Doors
    Overall "build thread" http://wayalife.com/showthread.php?2...ker-quot-build
  2. #2
    Been Around the Block Ausjeep113's Avatar
    Join Date
    Jul 2015
    Location
    Australia
    Posts
    257
    I've helped a few mates build winch bumpers but only done sliders and rear bumpers myself. Maybe someone with some more experience can chime in but Really 1/4" should be heaps strong enough as long as you have it solidly bolted to the frame.
    If you just box in the recessed area around where the winch will sit that should be plenty really. That will add so much more strength to the winch cradle and as long as the frame bolts don't let you down I'm sure it will be fine mate.
  3. #3
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    2,822
    I am using the EVO front d-ring mounts which bolt through the bumper, into the frame. Yes, that is my plan...to box in the winch mounting. I am leaving all of that to be added when I actually have a winch. I have a winch fund started but it will still be a little while. Thanks for the reassurance!
  4. #4
    Knows a Thing or Two SilverBack's Avatar
    Join Date
    Jun 2014
    Location
    American in Kosovo
    Posts
    774
    1/4 inch is more then strong enough as long as you used good steel most manufacturers use 3/16. As for the winch box, I can only say what I had to do with the winch plate I mounted. It connects to the frame inner part of the rails along the sides. This is where the weight bearing transfers from the winch to the jeep. I'm guessing that it isn't the only way to do it safely but maybe you'll want to connect the same way in addition to the 8bolts holding the bumper on. Then again, I may be way off base...
  5. #5
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    2,822
    Thanks! The steel came from a local steel/welding shop and it is legit 1/4". I figured on bolting the winch mount to the frame rails but wasn't sure 100%. That's part of the reason I'm holding off on that until I have a winch in hand, to test fit, measure, etc.
  6. #6
    Knows a Thing or Two kaptkrappy's Avatar
    Join Date
    Oct 2011
    Location
    Punta Gorda, FL
    Posts
    971
    I used a 1/4 steel plate between the frame rails.
  7. #7
    Join Date
    Feb 2015
    Location
    Cochise County, AZ
    Posts
    2,822
    Quote Originally Posted by kaptkrappy View Post
    That's what I've been picturing. Thanks for those pics!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
