Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Valve stem??
  1. #1
    Fresh Catch
    Join Date
    Mar 2015
    Location
    Temecula CA
    Posts
    22
    Valve stem??
    What valve stems are you guys running on your beadlock wheels??
  2. #2
    Old Timer HighwayTrout's Avatar
    Join Date
    Dec 2013
    Location
    California
    Posts
    3,388
    Factory with TPMS.
    en hopup veritas
  3. #3
    Join Date
    Oct 2012
    Location
    Utah
    Posts
    1,883
    Just a rubber one. I had a stock one seized up because I had deflated/inflated so many times. I broke off the alum and was screwed. Never again
  4. #4
    Addict jesse3638's Avatar
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,395
    Thread resurrection.
    Just pulled the trigger on some cooper stt pros. My valve stems are cracked and dry rotted to the point I can push one sideways and it'll leak. I know not safe...haha. I am going to replace them when I change the tires and am looking for recommendations. I plan on going with regular rubber non-tpms ones like I have now. Just looking for some suggestions. Any help is much appreciated.
  5. #5
    Join Date
    Dec 2013
    Location
    California
    Posts
    3,388
    I know when I ordered from direct tire a few years ago I got a set of 5 valve stems taped to a tire. I don’t remember paying for them and I definitely did not order them. Maybe yours will show up the same??
    If your not running tpm I wouldn’t think too much about it and grab whatever is at your local auto parts or tire shop.
    en hopup veritas
  6. #6
    Join Date
    Sep 2012
    Location
    Apple Valley, CA
    Posts
    5,395
    Quote Originally Posted by HighwayTrout View Post
    That's what I was thinking. I found a set of 6 plus all tools for $10 on Amazon during prime day. I'll probably start with those.
  7. #7
    Hooked Spazbyt's Avatar
    Join Date
    Oct 2015
    Location
    St.Peters, MO
    Posts
    246
    Not to derail the thread but if you have tpms and you break a valve stem off does the tpms sensor just fall into the tire? I just got a set of Colby emergence valve stems. To use them you have to pull the broken valve stem out.
  8. #8
    Old Timer TrailHunter's Avatar
    Join Date
    Apr 2016
    Location
    SoCal
    Posts
    4,120
    Quote Originally Posted by Spazbyt View Post
    If it doesn’t fall in, you could push it in. Is that what you are asking?
  9. #9
    Join Date
    Oct 2015
    Location
    St.Peters, MO
    Posts
    246
    Quote Originally Posted by TrailHunter View Post
    Ok thanks. When I bought the valve stem replacement I wasn't thinking about what happens to the tpms senor.
  10. #10
    Been Around the Block doubletapdaddy's Avatar
    Join Date
    Aug 2014
    Location
    Colorado Springs
    Posts
    352
    Yes, the sensor is only connected to the wheel via the stem. If you break the stem and reseal it externally, then the sensor will be bouncing around in the wheel.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
