Page 23 of 28 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 277
Thread: Tow rigs
  1. #221
    Old Timer wjtstudios's Avatar
    Nov 2016
    Rochester, MI.
    3,775
    Quote Originally Posted by bhaner View Post
    In what style and size? I didn't see anything on their site that high.
    The nitto Terra grappler in 295/60/20 also is 4080 and more of an AT instead of a MT tire.
    2015 JKU Rubicon AEV JK350
    1985 Jeep CJ8 Scrambler
  2. #222
    Nothing but a Thing jdofmemi's Avatar
    Mar 2018
    Menifee CA
    1,244
    Remember, axle ratings on single rear wheel is #7000. That is on a '16 F-350
    Yes, with the right tires and skill driving, you can go higher, BUT, once the ratings are exceeded, you are at risk legally, and most insurance will not cover the problem.
    When I was younger, I routinely hauled over the ratings on nearly everything I have owned, but I am older and I hope wiser now, so I don't admit to doing things like that anymore.😉
    I'm just throwing it out there as a reminder of the risks when things go wrong.
    Also, on the tire capacity, if you are within about 20% of the ratings, you are pushing it. Once near capacity, tires will start to sway and cause real problems, and speed makes it worse.
    If you are pushing the limit, slow down, and make frequent stops to check tire and bearing temperatures.
    Stay safe👍
  3. #223
    Been Around the Block bhaner's Avatar
    Jul 2017
    Wickersham, Wa
    295
    Quote Originally Posted by jdofmemi View Post
    Yep. Same on my 16 Ram 3500.
    It can be a problem when hauling a camper and towing a bumper pull trailer. Even with EQ bars on the trailer I am at 8000# on the rear axle.
    My next truck will be a DRW just for the peace of mind on long trips.
    Byron Haner - Wickersham, Wa
    -Currently Building-
    2016 JKUR HR
    Evo Offroad DTD w/Evo Lever
    Dynatrac Elite ProRock XD60/80
    40" Procomp MT, 17" B.A.D. Wheels
    My Build Thread
  4. #224
    Nov 2016
    Rochester, MI.
    3,775
    Stay safe
    Thank you! Yes, the 18’ Ram is the same. From your experience, is there an approximate ratio you use for tongue weight running a gooseneck or does it all depend on the trailer and how the load is distributed?
  5. #225
    Mar 2018
    Menifee CA
    1,244
    I mostly try to load based on the axle weight, as long as I can.
    Load the drive axle, but not overload it.
  6. #226
    Jul 2017
    Wickersham, Wa
    295
    Numbers for the new 2019 Ram 3500 came out today...
    400 HP and 1000 TQ. 7,630# payload and 35,100# towing capacity!
    That should do it!
    2016 JKUR HR
    My Build Thread
  7. #227
    Nov 2016
    Rochester, MI.
    3,775
    That should do it!
    Well, there you go! That’s massive, but I’d really hate to go DRW for a daily driver.
  8. #228
    Hooked maskale's Avatar
    Jan 2018
    Houston
    112
    2012 Ram 3500
    Gooseneck is 25' with 9' camper on it.
    The other is a 22', don't hardly use this for the Jeep anymore.
  9. #229
    Addict JKbrick's Avatar
    Feb 2013
    Leo, Indiana
    6,537
    That should do it!
    Did hp go down? Torque went up
  10. #230
    Jul 2017
    Wickersham, Wa
    295
    Quote Originally Posted by JKbrick View Post
    2018 was 385/930.
    My 2016 is 385/900.
    So a small bump in both.
    2016 JKUR HR
    My Build Thread
