Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Max tires 2004 WJ
  1. #1
    Hooked danco3636's Avatar
    May 2016
    Sacramento CA
    138
    Max tires 2004 WJ
    jeep grand cherokee performance 2004
    I currently have a 2" boost lift (RE) with stock 17" tires and currently 245/65/17.
    What is the max tire that would work on the current rims with an A/T tire.
    Here is my current tires. Would like to go just a tad bigger.
    Thanks for any help and suggestions.
  2. #2
    Hooked jamesrw30's Avatar
    Jan 2015
    Kingsport, TN
    185
    With or without trimming? I am on a 3 inch lift and running basically a 31 and can't go any larger without starting to trim. Those are basically a 30 (29.5 according to my tire calculator) so I don't know if you could go any larger without rubbing issues or starting to trim. I may be wrong however, there are lots of folks on here much more knowledgeable than myself.
    "After you have suffered a little while, the God of all grace, who has called you to his eternal glory in Christ, will himself restore, confirm, strengthen, and establish you." 1 Peter 5:10
    "The hosts of Heaven stand at attention as we make our way from earth to glory, and Satan's BB guns are no match for God's heavy artillery." Billy Graham
    http://www.flickr.com/photos/25682624@N06/
  3. #3
    Nothing but a Thing 2nd.gunman's Avatar
    Nov 2015
    Brisbane, Australia
    2,393
    I ran 245/45r17 on JK rubicon wheels on my WJ with a 2" lift. They just barely rubbed everywhere without any trimming. It was perfect.
  4. #4
    May 2016
    Sacramento CA
    138
    ️ that seems to be a smaller tire? About 25.7". Am I missing something?
  5. #5
    Nov 2015
    Brisbane, Australia
    2,393
    Quote Originally Posted by danco3636 View Post
    Sorry should have been 245/75R17 which is about 31.5"
  6. #6
    May 2016
    Sacramento CA
    138
    Looks sharpe. I think I may go that route.
  7. #7
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    28,093
    I did a 4 inch lift and 32s right when we bought this thing, so I probably can't answer your question. What I will say though, is check out Bushwackers fender flare video and it shows where you can/can't trim. If you decide to trim, it opens up a lot more options for tire sizes.
  8. #8
    May 2016
    Sacramento CA
    138
    Gong to add the 1.25 spidertrax wheel spacers to help bring out the stock rims. Perhaps I will put those on first and then assess tire size again.
  9. #9
    Fresh Catch
    Jun 2016
    Rio Rancho, NM
    13
    I have a 2010 WK, 3.5 lift in the front and 2.5 lift in the back, stock 18 inch rims. 1.5 spacers. I currently have 33x10.5R18 on it. I have very little rubbing. I did the pinch weld mod on the front, no cutting on the rear.
    Attached Images Attached Images
  10. #10
    May 2016
    Sacramento CA
    138
    Looks sharp. For some reason those tires don't look like 33's. But they fit in nicely. Are those Toyo AT's?
    Looks like I am going to do springs (2 inch rear and 2.5 front), a bit longer rear sway bar links and add an extra 3/4" spacer if needed for the front. The spacer was recommended for the V8. Then going to do 1.25 spacers with stock 17" rims and add fox shocks with a steering stabilizer.
    Once I get this all on I will see what tires may fit and look the best.
    Looking for an aggressive looking AT.
    Or perhaps the Toyo RT but not sure if they make them smaller than a 33 on a 17" rim. Need to investigate.
    Or these.
    ImageUploadedByWAYALIFE1467836189.982558.jpgImageUploadedByWAYALIFE1467836204.880360.jpg
