Page 44 of 44 FirstFirst ... 34424344
Results 431 to 436 of 436
Thread: CJ buggy build
  1. #431
    Been Around the Block klungly's Avatar
    Jun 2016
    poulsbo WA
    372
    Took off the old power steering pump brackets, cleaned and painted them. I was going to install the new pump, but I didn't have the right bolts on hand. The new pump is metric. I started working on mounting the radiator. I finished the lower mount and tacked it in. I figured out how I want to do the upper mount so it can bolt in and still keep the radiator snug.20180209_003015.jpg20180209_002958.jpg20180209_005516.jpg20180209_012345.jpg
  2. #432
    Jun 2016
    poulsbo WA
    372
    I went to start building my shock mounts and my axle isn't centered to the chassis. I did some measuring and found that my driver side frame rail was an inch further in and a 1/4 inch lower than the passenger side. BABOOZLE helped me get the rail to match the other. I had centered the upper axle control arm brackets to the truss and not the axle. I'll have to cut the old ones off and weld new ones on. I should have them thursday.20180214_001148.jpg20180214_001156.jpg
  3. #433
    Jun 2016
    poulsbo WA
    372
    I'm avoiding my control arm issue for now. One set of brackets is about 1/2" forward than the other. My new brackets will be here tomorrow. I'll move them when they come. Been working on the upper radiator mount. Need to finish trimming the tubing to fit.20180216_025812.jpg20180216_025912.jpg
  4. #434
    Jun 2016
    poulsbo WA
    372
    My wife got me a spare tire strap for my birthday and I'm pretty excited about it. A bunch of parts came in, so I should be able to stay busy for a while.20180216_102518.jpg20180217_105215.jpg
  5. #435
    Jun 2016
    poulsbo WA
    372
    Radiator mounts are tacked ikn and ready for final welding20180219_174854.jpg
  6. #436
    Hooked RockingK's Avatar
    Aug 2017
    Foresthill
    162
    Looks great, very nice workmanship
