Page 41 of 41 FirstFirst ... 31394041
Results 401 to 408 of 408
Thread: CJ buggy build
  1. #401
    Hooked Jaybird 11's Avatar
    Dec 2016
    Big Springs CA
    188
    Sttarting to look like a jeep now!👍
    Sent from my SM-G920V using WAYALIFE mobile app
  2. #402
    Old Timer jesse3638's Avatar
    Sep 2012
    Apple Valley, CA
    2,707
    Quote Originally Posted by klungly View Post
    My notches look pretty good with tires on. A little grinding is going to have to be done. The driver's side is a little too tight for comfort. The axle is set up for full compression. Attachment 289230
    I think you dropped your pinion... Looks good. This is a great build to follow. Its coming along nicely.
  3. #403
    Been Around the Block klungly's Avatar
    Jun 2016
    poulsbo WA
    344
    Nice to see the tires on. Does everything seem to fit pretty well?
    Yeah, everything fits well enough to move on to repositioning my lower control arms and building shock hoops. Once the notches are integrated into the role cage I'll go back and fine tune everything.
  4. #404
    Jun 2016
    poulsbo WA
    344
    Quote Originally Posted by Jaybird 11 View Post
    Things are getting exciting!
  5. #405
    Jun 2016
    poulsbo WA
    344
    Quote Originally Posted by jesse3638 View Post
    Thank you. I knew I forgot something... haha. That's the old pinion frolm the rear axle.
  6. #406
    Jun 2016
    poulsbo WA
    344
    I cut off two tube adapters from my lower control arms and put them iin the lathe at work and turned off the weld and milled the flats back in them.20180112_222823.jpg I wasn't happy with the shock mounts I bought. So I'm machining them to work better. 20180112_231402.jpg I started to make upper mounts as well. Another great setup20180112_222831.jpg
  7. #407
    Jun 2016
    poulsbo WA
    344
    Figured out where to mount the lower control arms so they're put of the way of the tires. They're tacked in place.20180118_214833.jpg started on tacking on the lower coilover mounts20180118_223911.jpg still need to finish fabbing the upper mounts and build the shock hoops.
  8. #408
    Sep 2012
    Apple Valley, CA
    2,707
    Looking good. Has to feel like some real progress now that you can see things coming together.
