NEW! Dynatrac JK44 Rear Axleshaft Bundle Kit
We know that not everyone needs a ProRock 60 or 80 rear axle for their 2007-2016 Jeep JK, so we put together a kit that helps you strengthen the weak points in a factory Dana 44 rear, and save about $300 in the process! The Dynatrac JK44 Rear Axleshaft Bundle Kit comes with our US-made 35-spline axleshafts fully assembled (bearings pressed on, wheel studs installed) and ready to install, exclusive billet axle retainers with studs that will NOT strip and spin, a 35-spline ARB Air Locker, and a nodular iron Dynatrac Pro Series diff cover.
https://www.dynatrac.com/axleshaft-kits/jk44-rear-35-spline-axleshaft-upgrade-kit-5-on-5.html
swampdog
This is sweet, had this been out when I went to a 35 spline rear, this would have been a no-brainer.
Journeyman
Can somebody educate me as to why this doesn't work on a rubicon 44 🤔
I'm assume it has something to do with number of splines on the axle.
Sport 44-30 spline?
Rubi 44-32 spline?
Can somebody educate me as to why this doesn't work on a rubicon 44 樂
Sport 44-30 spline?
Rubi 44-32 spline?
For one, Rubicon rear axles use 2 different axle shafts that are different lengths. Sport, Sahara and X model Dana 44 rear axles use shafts that are identical in length. The Rubicon's use a unique to it locker/carrier setup as well.
Journeyman
Hmm. That's good to know! That probably makes things a bit more interesting when it comes time to upgrade the rear end.
swampdog
What kind of warranty are we talking with these shafts?
Benito
So what upgrade options are available for a rear rubicon 44? What ARB is needed and does Dynatrac make shafts for it?
MR.Ty
Token East Coast Guy
You need to get the ARB that is for the rear Rubicon 44. Part # RD157
You'll also have to get Rubicon specific 35 spline shafts.
jesse3638
I see on your website this is only for non-rubicon axles. Is there a plan to release a rubicon specific version?
Edit: Your response above was not there when I hit submit...haha. I'm assuming the word "yet" means its in the works?
qwasin
Wow that is a great price dynatrac, good job. I have those same parts except revolution shafts instead, and spent a bit more. I was expecting your shaft price to be in RCV territory.
Also you rubi guys would come out ahead if you just sold your stock rubi axles and picked up a sport axle, or did a trade+cash with someone. Although if you've got custom bracketry welded on that complicates things.
chipper
Sweet , just in time. I was just talking about this the other day. Looks like a 35 - spline / arb is in my near future after all.
