Page 25 of 25 FirstFirst ... 15232425
Results 241 to 248 of 248
Thread: Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
  1. #241
    Addict JKbrick's Avatar
    Join Date
    Feb 2013
    Location
    Leo, Indiana
    Posts
    7,256
    I think he replied to the wrong forum
  2. #242
    Old Timer VeruGE*144's Avatar
    Join Date
    Feb 2017
    Location
    Illinois, Chicago
    Posts
    3,637
    They come in threes..... One more to go.
  3. #243
    Been Around the Block Basscat's Avatar
    Join Date
    Sep 2016
    Location
    Durango, CO
    Posts
    426
    So I’ve read most of this thread and have a quick question. RE: Caster; Given 6 degrees of separation on a stock set up with 4.2 + being optimal and 10 degrees of separation on a PR44 Unlimited with 6.0 + being optimal does the inclusion of geometry correction brackets with the PR44 Unlimited result in taking optimum caster back to factory spec of 4.2 +?
  4. #244
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    28,089
    Quote Originally Posted by Basscat View Post
    It could. But most likely it would increase the caster more that what the PR has. Some of the brackets have multiple holes for caster adjustment. If the arm is a fixed length, moving it directly down in a geometry correction bracket, will twist the axle increasing the caster. However if the bracket hole isn't directly under the OEM mount hole and it's further back to accommodate the length of the arm, the caster could stay the same. To the best of my knowledge, the bracket is more designed to bring the lower arms more parallel with the road rather than deal with caster.
    The difference of axle separation really isn't all that important if you just want to know what your caster angle is. Caster can still be measured on either axle whether you have brackets or not.
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  5. #245
    Join Date
    Sep 2016
    Location
    Durango, CO
    Posts
    426
    Appreciate the quick input. Was thinking similarly. It’s an AEV correction bracket (part of a 3.5” lift) on a 2013 JKU I got for my son. Adjustable front uppers are included. Would prefer to take correction brackets out and go with 6+ caster on the PR44 Unlimited but was curious if I left the brackets in would I then need to target 4+ on caster.
  6. #246
    Fresh Catch
    Join Date
    Dec 2018
    Location
    Florida
    Posts
    2
    Front end align
    Awesome write up,just purchased a 2013 jeep kj sahara for 30k. Whole front end needed replaced. I followed each step as close to the letter as possible and it rolls like a champ. Thanks from a veteran.
  7. #247
    Been Around the Block PokerStogey's Avatar
    Join Date
    Apr 2016
    Location
    Bakersfield
    Posts
    380
    This right here...
    Just another reason WAL sits at the top, great info. Just finished the flip kit for the EVO stage 1 last night and will be reading this again. Thanks Eddie!!!
  8. #248
    Fresh Catch AZchip's Avatar
    Join Date
    Jul 2019
    Location
    AZ
    Posts
    10
    I know, old post. But I joined today to find this information. Great info! Thanks for putting that concise information on alignment. I just installed a Metalcloak 3.5 Gamechanger. This is going to help me. Thanks again.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
