Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: M.O.R.E. Dual Battery Tray Installation Write-Up w/ODYSSEY Batteries (2007-11 JK)
  1. #21
    Hooked NOPULP13's Avatar
    Join Date
    Feb 2013
    Location
    Royal Palm Beach FL
    Posts
    102
    ok so i am a newb to the whole dual battery world I know on my tj i would have to rev up during winching or it would kill the battery very quick now with the new jk to avoid that can I just buy a dual battery tray and pop to batteries in and it will be like 1 huge battery or do they run separately like one to crank and one just for winch and accessories? what am i in for on this? future plans are a winch dual arb compressor maybe some lights, i never welded do i dont think I will need an on board welder so with those basic add ons will I need a dual battery?
    Tony
    "DESERT RAT"2017 Renegade Trailhawk - (MOJAVE SAND) Wife's ride
    "RDY2ROC" 2015 Rubicon Unlimited Hard Rock (TANK GREEN) BUILDING
    "NO PULP" 2013 2 Door Rubicon - being built slowly (CRUSH ORANGE) :-( TRADED IN
    "BLACK OPS 1989 YJ Stock. received in trade plus cash for TJ - Traded in (BLACK) :-(
    "RIOTMAKER" 1998 TJ lifted locked hp30 + 8.8 SOLD (RED) ;-(
    My write up Hard Top Dolly
    http://wayalife.com/showthread.php?7...325#post116325
  2. #22
    Hooked RodCyn's Avatar
    Join Date
    Oct 2011
    Location
    Los Angeles
    Posts
    168
    Sorry for not seeing the question above sooner. I have bought a painless wiring kit and had intended to install it but never got around to it due to all the transmission problems we were having. Now that we're doing an LS swap, I'm not even 100% sure we'll be able to keep our dual battery tray - we'll have to see.
    Regarding And 2nd, Die Hard Platinum and Odyssey, it is my understanding that the Platnum P-1's are made by Odyssey. I don't know if they are exactly the same in terms of performance though. I have run the P-1's in the past and they are a HUGE improvement over Optima Yellow Tops and I would highly recommend them too.
    Thanks for the advice and recommendations. Just picked up a pair of Diehards today and have a M.O.R.E. tray on it's way. Maybe it'll be a project for this weekend Now gonna go back and read your install instructions a few more times
  3. #23
    Caught the Bug onbelay's Avatar
    Join Date
    Jun 2013
    Location
    Auburn, Alabama
    Posts
    62
    Quote Originally Posted by NOPULP13 View Post
    You are describing the need for a dual battery system with an isolator (to separate them). If you run the batteries in parallel and connect the winch to one of them, you will most likely draw current from both, and deplete both. If you use an isolator, and again connect the winch to one battery, you will deplete only that one battery ... which is hopefully not the same battery you use to power your vehicle's electrical system.
    The JK alternator, depending on year, puts out about 160A. The stock TJ alternator (according to a Google search) puts out ~120A. That 40 amp delta is a huge difference! Even at 160A, however, you can deplete your battery during winching. Two ways to mitigate--but not entirely prevent--that:
    1. Rev the engine manually (or electronically if you're lucky enough to have a button, etc., to do this for you) like you have before.
    2. Buy a high output alternator that puts out more amps at lower RPMs.
    Buying a marine grade or deep cycle battery is also a good idea if you think you're going to deplete it.
    Below is an example of a wiring diagram for a dual battery system (I found this online; not my own drawing). Ignore the Amperage ratings on the accessory fuses; you would need something much larger for a winch. My guess is 200A or so.
    The "Intelligent Solenoid" depicted is something similar to a Cole Hersee 48530 isolator. They are included in most turn-key systems. Hope this helps.
    -Dawn (with help from Chris LOL).
    '08 Sahara Unlimited
    Coast 1310 front driveshaft
    3" Black Diamond lift
    17x9 ProComp 8128 wheels
    35X12.5 Toyo Open Country RT
    Yukon 5.13 gears
    ARB Lockers (F/R) & compressor
    LOD Gen 2 rear bumper & tire carrier
    LOD Armorlite front bumper & stinger
    JW Speaker 8700 Evo driving & fog lights
    Evo rock skins, sliders, high steer kit, LCAs
    Warn Zeon 10-S
    Genesis dual battery system + 34M Odysseys
    Hardwired 800W inverter
    Hotheads headliners
    Cobra 29, Icom ID-51A
    ARB 50qt freezer
  4. #24
    Join Date
    Jun 2013
    Location
    Auburn, Alabama
    Posts
    62
    Quote Originally Posted by Merlin75 View Post
    Two questions.
    Have you done the isolator wiring yet? I've got a similar setup in my 09 JK but am in the market for new batteries (as you know) and I've been frustrated recently because my starting battery is crapping out, and the isolator that I installed requires me to open the hood in order to self-jump. I was wondering if you had any suggestion on an isolator with a remote switch inside the cab. (lazy, yes.. don't hate!)
    And 2nd, I've read a lot about Die Hard Platinum vs Odyssey, are they really the same or are the guts different/batter in the Odyssey branded? (the price diff is $100+!)
    Thanks!
    We researched this quite a bit. The performance metrics are practically identical. We bought the Die Hard Platinum and have had no issues; the stock battery would have left us stranded in Mojave and then Big Bear had we not been wheeling with a partner. I wouldn't trust the stocker past 2 years.
    Yukon 5.13 gears
    Warn Zeon 10-S
    Hotheads headliners
    ARB 50qt freezer
  5. #25
    Banned Holeshot's Avatar
    Join Date
    Jul 2012
    Location
    Val-d'or/Quebec/ Canada
    Posts
    817
    I came across this kit the other day. I think it is pretty neat, might be on my list!
    http://www.genesisoffroad.com/store/...ttery-Kit.html
    And also went to my Odyssey retailer yesterday and, found that the right part number for the 2012+ jk's for an Odyssey Extreme is PC1500/34R (reversed poles), which retails at 332$ CAD.
  6. #26
    Hooked KennyFrench's Avatar
    Join Date
    Jul 2013
    Location
    Dublin, OH
    Posts
    129
    Question from another newb: I was wondering about putting aux lights, winch, compressor, and whatnot on a different circuit - including different fuse block? Or, is that the purpose an isolator/relay?
  7. #27
    Word Ninja Sharkey's Avatar
    Join Date
    Oct 2011
    Location
    Nevada
    Posts
    12,266
    Quote Originally Posted by KennyFrench View Post
    Nearly every accessory you run will be powered directly from the battery. You can pull power from inside the cab to turn on your switches, but the accessories themselves will need fused power directly from the battery (as opposed to the OEM fuse box). I've seen people tap open fuse spots in the OEM box, but it isn't worth the hassle in my opinion.
    For your average set of lights, I run a fused power line from the battery to a relay, a ground to the relay, a wire to from the relay to the lights, and a wire from the relay to a switch in the cab. The switch will also have its own ground wire and, assuming it has a light, a hot wire tapped into a source in your dash (such as the 12 volt outlet). Depending on your needs the size of wire, relay and fuse may differ. I tend to overkill my wiring with 12 gauge wire, 30 or 40 amp relays, and 30 amp fuses.
  8. #28
    Knows a Thing or Two Paisano's Avatar
    Join Date
    Oct 2012
    Location
    Encinitas, Ca
    Posts
    653
    Do you have a dual battery set up? My aux lights run through my SPod which is wired to my secondary battery SPod has its own fuses. My winch is wired directly to my secondary battery. Yes that is the purpose of my dual battery isolator.
    "Once this baby hits 88 miles per hour, you're going to see some serious s*&t"
  9. #29
    Living the WAYALIFE MTG's Avatar
    Join Date
    Jan 2012
    Location
    Reno eNVy
    Posts
    13,638
    Quote Originally Posted by Paisano View Post
    Where did you put your second battery? You have a 2013 right?
  10. #30
    Join Date
    Oct 2012
    Location
    Encinitas, Ca
    Posts
    653
    Quote Originally Posted by MTG View Post
    Yes it's a 2013, here's a pic.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
