Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: M.O.R.E. Dual Battery Tray Installation Write-Up w/ODYSSEY Batteries (2007-11 JK)
  1. #31
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    27,683
    Eddie, you still running this dual battery setup? I'm not familiar at all with a 2 battery system. I assume as long as both positives are touching each other and both negatives are touching each other, then it is still a 12v system correct? And the alternator still charges both of them at the same time? Any risk or issues?
    Then for welding, you would run them in series, disconnect everything and run a positive wire to negative on the other battery to create a 24v system?
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  2. #32
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    52,271
    Quote Originally Posted by WJCO View Post
    I am no longer running this setup as I am now running an LS and it wouldn't fit. You can run it as you have described but it would be more beneficial if you ran it with an isolator system. There are a few companies like Painless Performance that make a kit for this. For welding, yes, you would need to disconnect them and run them in series. If you're using something like a Premier Ready Welder II, you would need to have it set for this as well.
  3. #33
    Join Date
    Mar 2015
    Location
    The OC
    Posts
    59
    Does anyone know if the MORE Dual battery tray will interfere with the EVO Bolt on Coilovers? I'm looking at installing one after the other and am thinking the ribs underneath the battery tray are the ones I'm supposed to trim when installing the front passenger coilover tower.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
