Custom Rock Sliders Install questions
JKU Arizona
So I decided to fabricate a set of rock sliders and i have a few install questions. I'm leaning towards welding them on vs bolting them on. My only concern is welding near the gas tank. Is there any precautions i have to take/consider? should i drop the tank? fill it up so there's no vapors in it? or is it pretty safe to just weld next to it the way it sits?
I'm not a professional welder, i decided to buy a welder along with a few other metal working tools a few months ago (to do hobby projects). So instead of dropping 500-600 on a set i've decided to make my own out of 1 1/2" .120 dom round tubing and use that money towards other mods. There's about $150 worth of material and 2 partial weekends so far. They're pretty much done waiting for paint to cure before installing them. Decided to check in with you guys on opinions regarding the welding next to a gas tank question.
Thanks!
You can get a wool blanket from an army surplus store and wedge it in there. Also, I would recommend disconnecting the battery when welding on a vehicle.
JeepJeep75
Modern gas tanks are very well sealed up. If there's even a slight leak in the tank anywhere the computer will let you know. So, unless there's gas dripping out onto the ground you should be good to go. I don't think you have anything to worry about. I welded my sliders on no problem. Do you plan on beating those sliders up? Reason I ask is you only have one support on each end of your slider. Do you think that's enough to support and catch the jeep from a slight fall off of a rock onto your slider? Nice looking welds BTW! [emoji106]
JKU Arizona
There's 3 supports on there now. I didn't realize that there's more space in the back from the frame to the body so i needed to cut them down (the very front one is about roughly 1 1/2" smaller the center one is roughly 3/4" smaller than the very back one. and when i took the pictures i was actually test fitting the center support. I havn't wheeled in any area that I've mad rock contact with the stock rubi sliders. But just want to be prepared as i'm planning on doing a little more aggressive trials here soon.
JeepJeep75
Cool man, they look good!
hinrichs
Sliders look good. I would add some gussets for where the tubes meet the feet for a little extra bracing :thumb:
zimm
Those look really nice! Better than my welds. I had no problem with the fuel tank. As mentioned, disconnect the battery so you don't fry anything. I used a harbor freight fiberglass blanket and $9 arm sleeves to protect myself.
USMC Wrangler
Looks great so far and subscribed! These are my next planned DIY fab items too. [emoji106]
I'd agree that welding by the gas tank is safe as long as there are no leaks.
JKU Arizona
What did you use the fiberglass blanket for? is that it underneath?
Good call on disconnecting the battery. I wouldn't have thought of that.
JKU Arizona
I have a CAD drawing i did with dimensions, i'll post it on here a little later today. I have a whole list of items i'm thinking of fabricating. I do engineering work (furniture and cabinets) so i usually draw in CAD before i do any cutting.
Heavyhaul07
Looking good. I wouldn't worry about welding next to the tank. I did mine. You should always disconnect the battery before welding on a vehicle.
JKU Arizona
Damn they look awesome! What kind of welder are you using?
I'm using a miller millermatic 211 welder. It has an auto-set feature that's worked out really great for me (again i'm not a professional welder) all you have to adjust is the thickness of the materiel and you're ready to go.and i used a cheap harbor freight tube notcher attachment for notching out all the tubing. This was my first time welding tube together but overall i think i did good.
