Page 23 of 40 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 394
Thread: New Evo Mfg pro series hinged gate
  1. #221
    Nothing but a Thing zimm's Avatar
    Join Date
    Oct 2015
    Location
    Ft. Lauderdale, FL
    Posts
    1,050
    I'm halfway there. I got the hinge installed at least. Of course I had to pull my entire CB coax from the radio all the way out through the tail gate to get it out of the ACE tailgate plate. Phew! Then it was a wrestling match to get the 9/16" bolts in place. After I hammered them in I realized I forgot the washers. Son of a bitch. I got them out with a punch, put the washers on, and got them seated. Then I fought the stupid spacer plates that hang on the hinge bolts and try to line it all up and get the bolts started. The first 10 attempts resulted in a spacer or bolt dropping out of place. Once it was finally bolted on, I realized I had the tire carrier set too low. So I took the carrier bolts out again, raised the mount, and redid the spacers and bolts. So all in all, it took me 2.5 hours so far, instead of what should have been a 30 min job. I also left a "pull wire" in place so I can pull the license plate light wire through the tail gate when I get it.
    I'll report back tomorrow after I get the tire on, license plate moved, and remove the bumper.
    2015 JKU Rubicon
  2. #222
    Nothing but a Thing JKDream's Avatar
    Join Date
    Jul 2016
    Location
    Canada
    Posts
    1,043
    For those of you running this carrier: does it completely replace the factory tailgate hinges? I want to switch from my shitty carrier, but I had to cut the OEM hinges apart.
    Sent from my Le X821 using WAYALIFE mobile app
    **Edit - Post directly above answered my question..
  3. #223
    Join Date
    Oct 2015
    Location
    Ft. Lauderdale, FL
    Posts
    1,050
    Quote Originally Posted by JKDream View Post
    YES it does. Aside from my complaining, it's a super heavy duty piece. I've very happy with it so far. I also didn't need to drill out the door stop and use their adjustable bracket, I bolted the factory tail gate stop back in place and it works fine.
    2015 JKU Rubicon
  4. #224
    Join Date
    Oct 2015
    Location
    Ft. Lauderdale, FL
    Posts
    1,050
    Got it all done. The tail gate swings better than stock. I'm so happy with it. I'm still waiting on the ACE fascia and D-ring things. I zip tied the 7 pin connector above the frame since it would hang too low under. Not sure for a permanent solution. My 3' CB antenna is now too tall for my garage, so I ordered a 2' firestick with spring. That should fit. The back up lights are on the way, and the back up camera will go on after the fascia is installed. The factory hitch is 7" closer to the frame than the Ace bumper hitch, that should make a big difference with tongue weight.
    2015 JKU Rubicon
  5. #225
    Nothing but a Thing TRLJNKY's Avatar
    Join Date
    May 2016
    Location
    Carson City, NV
    Posts
    1,180
    Looks good!
    sent from my Illudium Q-36 Explosive Space Modulator
    Formerly known as cavfighter
  6. #226
    Nothing but a Thing boardsurfer's Avatar
    Join Date
    Jan 2015
    Location
    5280
    Posts
    1,111
    Quote Originally Posted by zimm View Post
    Nice work! Those spacers can be difficult. Dont feel bad, I took mine apart a few times to get things lined up properly and chasing down a squeek.
    Quote Originally Posted by mudmobeeler View Post
    Rare doesn't make it desirable. It's rare that I shit my pants, but when I do it's usually not desirable. Lol.
  7. #227
    Fresh Catch
    Join Date
    Apr 2017
    Location
    Indiana
    Posts
    25
    EVO Hinge Gate Carrier Install
    I'm probably late to this post and as I'm new to this forum, be kind making fun of me!
    I just installed the EVO hinged tire carry and want to share some of my experiences - some of which are the same as some folks here.
    Overall, this thing is a tank. It installed without too many issues but the ones i had were a pain in the butt. So here's my issues:
    1. I love EVO, but I hate the packaging and the peanuts! That took me a good 20 minutes to deal with.
    2. There are two spacers that are a pain in the butt to install behind the carrier. I simply taped the things together and then taped them to the carrier. It made installing the bolts through the carrier and through the spacers into the tailgate a cakewalk. When installed, you can't see the tape.
    3. As someone mentioned here, go to Lowe's and get some longer stainless steel bolts for the spacer pieces. The stock bolts, while just about long enough, really don't have enough thread to bite on. EVO, for $650 bucks, please include some bolts!
    4. The hinge bolts would not fit into the hinges no way, no how. I had to use a dremel and slowly grind away the holes until the 9/16 hinge bolts would fit.
    Again, Overall, this rack is a tank and built very well. My buddy has the Teraflex carrier and it doesn't measure up to this. The tailgate is solid and doesn't rattle at all. I like this carrier because the holes for mounting the tire carrier part (See my pics) allowed me to use this carrier in many ways. I simply tapped the holes in the carrier so I could install a jerry can holder, a mtn bike rack, hi lift jack, and of course my spare tire - although, I carry my spare in the cargo area of the Jeep using a custom made tire carrier. I also designed a way to attach and detach the third brake light - sorry, I didn't take pics.
    It's a great carrier and I highly recommend it. I hope my install helps people out!
    Attached Images Attached Images
  8. #228
    Addict catahoula's Avatar
    Join Date
    Nov 2011
    Location
    Colorado
    Posts
    7,051
    The Ace fascia and rings are a pretty sweet deal. Will look nice on your rig!
    Gots
    17-Inch Rubi Wheels
    295/70/17 Mastercraft Courser MXT's
    18/59 Springs & Rubi Shocks
    TF Leveling Kit
    1.5" Spidertrax Spacers
    Warn Rock Crawler Stubby & Engo 9000 Winch
    EVO Rear Bolt On "D" Ring Mounts
    EVO Rear Corner Rock Skins
    Rough Country Skids
    “Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do...
    Explore. Dream. Discover."
    "Take a compass, because it's always awkward when you have to eat a friend."
  9. #229
    Hooked IBSMSHN's Avatar
    Join Date
    Jun 2016
    Location
    San Diego Ca.
    Posts
    219
    Yes I agree ... best tailgate carrier! EVO.... that's what holds my 37. Just got tired of hearing and seeing my tire bouncing around so I bought this carrier and drive even harder over ruts, whoops etc... just so I can talk s*#*... lol and I can't!!! LOVE THIS THING... thanks EVO
  10. #230
    Join Date
    Jun 2016
    Location
    San Diego Ca.
    Posts
    219
    Well that's mine opinion
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
Join us
WATCH OUR VIDEOS
