Page 39 of 43 FirstFirst ... 293738394041 ... LastLast
Results 381 to 390 of 426
Thread: New Evo Mfg pro series hinged gate
  1. #381
    Guy with a Red 2-Door cozdude's Avatar
    Mar 2013
    West Chester, PA
    19,053
    Quote Originally Posted by Benito View Post
    It was holding the tire just fine, just don’t drag ass!
    Attachment 282761
    This happened this past weekend while coming off of a ledge. The damage was isolated to brackets holding the tire, no damage transferred to the tailgate!
    Attachment 282762
    Attachment 282763
    Attachment 282764
    I️ have replacement parts on the way!
    Here you go mybadjk. You can see where it bent
    October 16, 2013, wednesday early evening, east of the pacific ocean, selectee for truly random and boring Parking lot photo of the moment grand platinum prize winner!
    2011 JK
    EVO Bolt-on Coilovers, EVO 1/4 pounder w/ stinger, 37" Cooper STT Pros, PR44, and some EVO stuff
    Awaiting install-
    On Order-
    Want list- Evo carrier and skins, PSC hydro assis
    jlwrangler.com
  2. #382
    Fresh Catch
    Nov 2017
    mexico
    3
    clunk noise at my gate....
    Hey guys... first of all thanks for all the info you have here,
    i just installed my tire carrier, i changed the gate stopper hinge as the instruction said, but now i have a very bad clunk noise every time the stopper "gets in or out" the stop...
    i read that only with some minor changes in the bolts could be fixed, but is still the same... Do you have any tip to make it disappear???
    here you can se what im talking about , just mine stills with the noise...
    https://www.youtube.com/watch?v=10W_rgk3QN8
  3. #383
    Nothing but a Thing boardsurfer's Avatar
    Jan 2015
    5280
    1,737
    Quote Originally Posted by sanham View Post
    I left the stock arm in there. The instructions said that the arm provided with the kit was optional (I think) so I just left it alone.
    Maybe go back to the original arm? Maybe the bolts are too tight and stripped in the tailgate?
  4. #384
    Fresh Catch
    Nov 2017
    mexico
    3
    Quote Originally Posted by boardsurfer View Post
    Ill try to go back to original......
    tell you later how it goes...!!!!!
  5. #385
    Caught the Bug BPA's Avatar
    Jun 2015
    Santa Clarita
    91
    Looks like those two bolts connected to that hindge are loose. Mine does the same until I tightened them up.
  6. #386
    Fresh Catch
    Nov 2017
    mexico
    3
    solved.....
    Results that if the bolt diameter is not exactly the same than the inner diameter from the door arm, so it will make noise every time you full open and close the rear gate. as the same if the small hinge bolts are loose.
    so, step one make sure that the bolts are very tight, step two made a head shaft who can be locker with a truac lock and voila.... the noise is gone off course the hinge holes and the door arm holes are the same diameter and the shaft is little bit tight in them... so there is no space for movement here are some pics..
  7. #387
    Jan 2015
    5280
    1,737
    Ah, good to know! Thanks for following up.
  8. #388
    Knows a Thing or Two aTX427's Avatar
    May 2017
    TX
    923
    Attachment 282761
    Did the tailgate bend?
  9. #389
    Old Timer Clutch's Avatar
    Dec 2015
    STL metro
    2,841
    His build thread said only the 2 metal brackets to the carrier bent. Tailgate was fine, he also said if the hardtop was on the window would’ve been busted.
  10. #390
    Nothing but a Thing Benito's Avatar
    May 2013
    New Mexico/Texas
    1,293
    Quote Originally Posted by aTX427 View Post
    No, it held great, i have the tire back on there already, I’m thinking of getting a hitch skid to try to prevent this from happening again. It cost $130 to replace both brackets.
