Results 1 to 7 of 7
Thread: Running light trouble
  1. #1
    Knows a Thing or Two JKU EXTREME's Avatar
    Mar 2013
    Harlingen, Texas
    565
    Okay, so I'm having trouble with my running lights in the front, but more importantly the rear. I have checked all the fuses, and replaced the ones that needed replacing. The reverse lights work and so do the brake lights, but the daytime running lights do not work at all. I installed some aftermarket backup lights, hard wired to the existing reverse light wires. I have even disconnected them to see if that would help, it didn't. I'm not a huge wiring guy or anything of the sort, so if someone could assist me that would be great.
    2013 JKU
    Thanks
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    The Matrix
    32,562
    Do they work if it's not set on 'auto' mode? So if you manually turn on the headlights and tail lights, do they work then?
    "A Republic, if you can keep it." -Benjamin Franklin
  3. #3
    Mar 2013
    Harlingen, Texas
    565
    'Auto' mode?
    They don't come on at all
  4. #4
    Sep 2015
    The Matrix
    32,562
    Quote Originally Posted by JKU EXTREME View Post
    'Auto' mode?
    I was asking if you can manually turn them on or if there is an 'auto' mode where they turn themselves on only after dark. Either way, it's sounding like an issue with the multi-function switch as you said the fuses are good. If all 4 corners aren't illuminating......
    You could use a test light and check for power at each bulb or power before and after fuse and see where the problem lies. It's time consuming though.
  5. #5
    Nothing but a Thing rogerk93's Avatar
    Sep 2014
    yonkers, NY
    1,005
    It can be the bulb. The rear has dual filament one for the running lights and one for when you press the brakes. One of the filament burnt out. Change the light bulbs.
  6. #6
    Mar 2013
    Harlingen, Texas
    565
    Quote Originally Posted by rogerk93 View Post
    I changed the bulbs a while back but then the both lights went out. I'm going to go by the dealership to see if it's not under warranty
  7. #7
    Fresh Catch
    Jul 2016
    New Lenox, IL
    20
    Do your running lights work when you take out the new lights that you put on? You have to be careful with adding another load onto an existing circuit, especially with LEDs. I had this same problem with I bought a JKS LED license plate bracket. The directions said to tap into the rear tail light and it screwed everything up. Luckily, my dealership was cool and fixed it under warranty.
